Re: Samsung PN60E6000GF 60" Smart TV turns off, red flashing power light
See the silicone "blob" on the bottom of the power supply board ?
Remove it and clean the area with denatured alcohol then
re-solder the pins of the regulator IC.
HTH.
Now the TV is just trying to mess with me..
Last night I tried the blow dryer and heated the power board and main board separately; each for about 5 minutes. The TV did not turn off during this time. I then found out it had a default 15 minute timer to shut off if no input. I turned that off, and played a 90-minute video off a USB. The TV stayed on the whole video and stayed on the whole night (about 9 hours). From here, I figured it was fixed after the reset and was just being stupid about that 15min timer. I put it together and remounted it, for it to only turn off at random intervals again. Now it turns off after about 2-5 minutes, and I have tried to reset it again, without success.
One time it turned off after it was reset (during the setup process), but the sound was still present (just no picture). Not sure if this helps to determine which board it could be.
Also, it does not seem to decrease in duration now. It could stay on for 60s, and be turned off (after unplugging it) and then be on for 2 min.
Thanks and I appreciate the help so far.Leave a comment:
cool,so main,logic board,sn,buffers and x main seem to work ok.
Back at the power supply. Or logic board but most likely power supply.
Saying that time it stays on decreases almost makes it sound like heat sensitive.
Have a can of air? If held up side down it sprays freon,thus freezing a target area. Got a hair dryer? I would heat up the powersupply in lets say a 1/4 area of the board and see if it shuts down sooner. Once area is found that seems heat sensitive,you can then use can of air upside down to freeze that area and pretty close target the component.
Try that also with the logic board,those BGA chips sometimes let go and then need a reflow.Leave a comment:
--Update--
Resetting the TV got it to stay on longer. Each time I left it on, the duration that it stayed on, seemed to decrease. The TV is up to date on firmware, and obviously did not let me downgrade the version.
Just reattempted shorting the 3/4 pin (and found the thread for it). When doing that, with the cable removed connecting the logic board to the main board, it displayed a series of colors. Started white and then cycled to through blue, red, etc. Without doing anything, the TV did turn off during this process. I also reattempted it a few times, and the TV did the same thing (I believe how long it stayed on for, decreased each time too). Not sure if the pattern or order of colors matters.
ThanksLeave a comment:
I found out the IR sensor was likely blocked when I had it on the floor.
The more I look into this problem, it appears to be a possible firmware issue. So I just reset the TV and have it on at the moment. Will wait to see what it does/doesn't do. Maybe update the firmware if problem persists and see if that fixes it.
Otherwise I will reattempt to get the test mode working if resetting doesn't work.Leave a comment:
Now,on most samsungs what you do is disconnect the cable between the logic board and the mainboard,then make a short between 3&4 on the logic board,right top of board. Then plugin the tv,it should now display a variety of test displays.(on some you need to hit the power button).
Try that,with vs and va giving those voltages I'd say power supply is working yes.
Disclaimer: I don't know a whole lot about this model. Merely trying to help you to narrow down the problem board and some basic tests till somebody with more knowledge jumps in
Given when trying this, the TV is resting on the floor (no stand) and I am unable to press the power button. So I was trying to use the remote, could that be the reason for not getting the testing screens?Leave a comment:
Disclaimer: I don't know a whole lot about this model. Merely trying to help you to narrow down the problem board and some basic tests till somebody with more knowledge jumps inLast edited by martino; 05-27-2016, 08:49 PM.Leave a comment:
Behind the black plastic part for the stand is another board,the logic board,can we get a close up picture from that? Wanna see if we can get it to run the test patterns.
And maybe swap out that wired cap for the good of Alastairs blood pressureLast edited by martino; 05-26-2016, 08:49 PM.Leave a comment:
--Bump--
I would be willing to donate some coin if someone can help. Just annoying having a 60" broken and using a 30" as a tempLeave a comment:
--VS--
Actual: 221.8
Rated: 219.0
--VA--
Actual: 55.1
Rated: 55.0
Since I believe these are within reason, and no signs of blown caps, should I assume the power board is fine?
Edit: I should also mention that since I owned the TV (for the 2 weeks it worked), it would intermittently go black and then go back to the picture and say "HDMI2" or etc. I didn't think much of it before, as I figured it was either my HTPC or the HDMI cord bottling the throughput, but now I realize that could mean T-sys board too?
Edit 2: I was checking the VSC and it was about 10v off. Then the TV turned off like it has been doing. I then retested the VS/VA and it was something like 70v/10v, respectfully.. Not sure what to make of this personally.Last edited by kyij; 05-25-2016, 01:41 PM.Leave a comment:
Let me go ahead and check.Last edited by kyij; 05-25-2016, 12:36 PM.Leave a comment:
Why on Earth--is there a cap hanging off that board instead of being fitted correctly!
--recipe for disaster, that!Leave a comment:
https://www.badcaps.net/forum/showth...V+REPAIR+GUIDELeave a comment:
Look on the power supply firstly you will have VS/VA test points measure them to see what you get they should match up with your panel sticker voltagesLeave a comment:
Have you checked to see what supplies come up and if any do not?Leave a comment:
by learnmoreHello Community!
CASE DETAILS
Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
Tried inserting firmware on USB and left it in for a few hours, but no change
by BloopetaHave a Samsung UE43KU6400U that will not turn on, just continuous flashing red standby light.
Power button does nothing
Have unplugged the mainboard, and backlights illuminate.
Have tried removing panel ribbon cables one at a time, and that makes no change.
With mainboard unplugged, all voltages from powerboard seem ok, but with mainboard connected, they never quite reach full voltage, and drop and raise in a constant loop (in time with click noise from mainboard.
Using backlight tester, I get 63.6v on both sides, so seems like no bulbs... -
by Phil289Hi
I aquired a Samsung UE46EH5000 from a lady that said it was turning on and off so she just purchased a new one.
On plugging into the mains and turning on i get a solid red light.
On using the on/off button or remote i just get a flashing red light in a pattern of flash/flash gap flash/flash gap flash/flash etc.
Opened it up and disconnected the main board from the power board by removing the connecting ribbon cable with the hope of getting either a 'no backlight' or a 'working backlight' but got neither,i just got a blinking backlight that turned on and off randomly... -
by 7onyThe TV is a 2013 Samsung plasma, model # PN60F5300AFXZA.
Snagged it up in non-working condition a couple years ago. Previous owner said that sometimes he could get it to come on after repeated tries but other than that he couldn't get it to turn on.
Personally I haven't been able to get it to turn on at all. The standby light comes on solid when plugged in, but pressing the power button results in the standby light flashing once every 4 or so seconds. No "click" noises, no light from the panel at all. Just the flashing standby light.
No visible... -
by esqmoooHello everyone.
This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
I tried long pressing on the power button, after several seconds it would go off then when the button is released... - Loading...
