Samsung PN60E6000GF 60" Smart TV turns off, red flashing power light
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Re: Samsung PN60E6000GF 60" Smart TV turns off, red flashing power light
    Now,on most samsungs what you do is disconnect the cable between the logic board and the mainboard,then make a short between 3&4 on the logic board,right top of board. Then plugin the tv,it should now display a variety of test displays.(on some you need to hit the power button).
    Try that,with vs and va giving those voltages I'd say power supply is working yes.
    Disclaimer: I don't know a whole lot about this model. Merely trying to help you to narrow down the problem board and some basic tests till somebody with more knowledge jumps in
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • kyij
      • Jul 2013
      • 45
      Thanks for the reply. When disconnecting the main board and logic board, and shorting pins 3/4, nothing would display on the TV. When leaving the boards connected and shorting the pins, the tv came on as normal, but did not display any test displays.
      Given when trying this, the TV is resting on the floor (no stand) and I am unable to press the power button. So I was trying to use the remote, could that be the reason for not getting the testing screens?
      • kyij
        • Jul 2013
        • 45
        I found out the IR sensor was likely blocked when I had it on the floor.
        The more I look into this problem, it appears to be a possible firmware issue. So I just reset the TV and have it on at the moment. Will wait to see what it does/doesn't do. Maybe update the firmware if problem persists and see if that fixes it.
        Otherwise I will reattempt to get the test mode working if resetting doesn't work.
        • kyij
          • Jul 2013
          • 45
          --Update--
          Resetting the TV got it to stay on longer. Each time I left it on, the duration that it stayed on, seemed to decrease. The TV is up to date on firmware, and obviously did not let me downgrade the version.
          Just reattempted shorting the 3/4 pin (and found the thread for it). When doing that, with the cable removed connecting the logic board to the main board, it displayed a series of colors. Started white and then cycled to through blue, red, etc. Without doing anything, the TV did turn off during this process. I also reattempted it a few times, and the TV did the same thing (I believe how long it stayed on for, decreased each time too). Not sure if the pattern or order of colors matters.
          • martino
            Not so "senior"
            • Aug 2013
            • 997
            • canada
            cool,so main,logic board,sn,buffers and x main seem to work ok.
            Back at the power supply. Or logic board but most likely power supply.
            Saying that time it stays on decreases almost makes it sound like heat sensitive.
            Have a can of air? If held up side down it sprays freon,thus freezing a target area. Got a hair dryer? I would heat up the powersupply in lets say a 1/4 area of the board and see if it shuts down sooner. Once area is found that seems heat sensitive,you can then use can of air upside down to freeze that area and pretty close target the component.
            Try that also with the logic board,those BGA chips sometimes let go and then need a reflow.
            • kyij
              • Jul 2013
              • 45
              Thanks for the quick and detailed response. I will give this a try tonight. Do I have to worry about any condensation from the compressed air?
              • kyij
                • Jul 2013
                • 45
                Now the TV is just trying to mess with me..
                Last night I tried the blow dryer and heated the power board and main board separately; each for about 5 minutes. The TV did not turn off during this time. I then found out it had a default 15 minute timer to shut off if no input. I turned that off, and played a 90-minute video off a USB. The TV stayed on the whole video and stayed on the whole night (about 9 hours). From here, I figured it was fixed after the reset and was just being stupid about that 15min timer. I put it together and remounted it, for it to only turn off at random intervals again. Now it turns off after about 2-5 minutes, and I have tried to reset it again, without success.
                One time it turned off after it was reset (during the setup process), but the sound was still present (just no picture). Not sure if this helps to determine which board it could be.
                Also, it does not seem to decrease in duration now. It could stay on for 60s, and be turned off (after unplugging it) and then be on for 2 min.
                Thanks and I appreciate the help so far.
                • Terryfictv
                  • Mar 2011
                  • 124
                  See the silicone "blob" on the bottom of the power supply board ?
                  Remove it and clean the area with denatured alcohol then
                  re-solder the pins of the regulator IC.
                  HTH.
                  • kyij
                    • Jul 2013
                    • 45
                    HTH.
                    Are you talking about the silicone blob "1" or "2"? Do you think it has to be replaced or just resoldered? Thanks
                    • Terryfictv
                      • Mar 2011
                      • 124
                      on the BOTTOM of the board
                      • kyij
                        • Jul 2013
                        • 45
                        Okay. Working on it now. And sorry for my ignorance, I just only saw a relay, an inductor, the 275v relay. Plus what looks like a green resistor? Did not see what appeared as a regulator IC, hence why I asked.
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          #32
                          There appears to be components legs going through the power supply board from top to bottom and then connecting to the opto-isolators. The strange thing is I would have thought they would have soldered these components in because other componets on the bottom of the board are left with a very thin copper track to these IC's because of the hole drilled out out the centre of the pads. I think it would be worth doing a continuity check.
                          • Terryfictv
                            • Mar 2011
                            • 124
                            Remove clear "blob" on the solder side of board ( area #2 )
                            Leave white blob on component side alone for now !
                            • kyij
                              • Jul 2013
                              • 45
                              Yea I should've known you meant the solder side. I am almost done cleaning the area but here is a picture. Although I am not 100% certain which solder joints are for the regulator IC. On other areas of the board, they seem to be denoted with a "Q" but I do not see that in this case. Highlighted is the 3 pins I believe could be for it, but again, not certain.
                              Edit - now that I look at that region, I am not even sure those are for it, as the upper solder joint of the triangle appears to be connected with the solder joint to the right of it.
                              • kyij
                                • Jul 2013
                                • 45
                                I see what you mean. There appears to be a wire on the flip side that connects two of the legs of the opto-isolators. When I was searching more on these, it seems like they should be tested against resistance rather then continuity. The continuity 0's for a few leads but the resistance varies from each pair.
                                • Terryfictv
                                  • Mar 2011
                                  • 124
                                  Use an old toothbrush and alcohol to clean area.
                                  Pins are two offset rows.....
                                  Take another pix when clean....
                                  • Terryfictv
                                    • Mar 2011
                                    • 124
                                    Ooopps! Evidently the removed blob was not covering the pins of the IC !
                                    Can you take a close-up pix of component side beneath area 2 ?
                                    • kyij
                                      • Jul 2013
                                      • 45
                                      Not a problem as I know it's hard to tell from just pictures. Took a picture of the front and the back, for comparison. Let me know if you need a closer up picture.
                                      I know there are a lot of repair kits sold online for the Samsung power boards which contain these regulator IC's. Do you think they just need resoldered or replaced? Is there a way to test them without applying a input voltage?
                                      PS: It does look like there is some corrosion on the QS802, think that is the issue?
                                      • Terryfictv
                                        • Mar 2011
                                        • 124
                                        Pix of component side divided in four quadrants ( half / half = too large )
                                        So, four pix should show with magnifier....
                                        • kyij
                                          • Jul 2013
                                          • 45
                                          Attached are each quadrant.
                                          • learnmore
                                            Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
                                            by learnmore
                                            Hello Community!
                                            CASE DETAILS
                                            Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
                                            13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
                                            Tried inserting firmware on USB and left it in for a few hours, but no change
                                            03-03-2024, 09:49 AM
                                          • Bloopeta
                                            Samsung UE43KU6400U Flashing Red Standby Light
                                            by Bloopeta
                                            Have a Samsung UE43KU6400U that will not turn on, just continuous flashing red standby light.
                                            Power button does nothing
                                            Have unplugged the mainboard, and backlights illuminate.
                                            Have tried removing panel ribbon cables one at a time, and that makes no change.
                                            With mainboard unplugged, all voltages from powerboard seem ok, but with mainboard connected, they never quite reach full voltage, and drop and raise in a constant loop (in time with click noise from mainboard.
                                            Using backlight tester, I get 63.6v on both sides, so seems like no bulbs...
                                            09-11-2023, 02:34 AM
                                          • Phil289
                                            Samsung UE46EH5000 - Flashing red light but not turning on
                                            by Phil289
                                            Hi
                                            I aquired a Samsung UE46EH5000 from a lady that said it was turning on and off so she just purchased a new one.
                                            On plugging into the mains and turning on i get a solid red light.
                                            On using the on/off button or remote i just get a flashing red light in a pattern of flash/flash gap flash/flash gap flash/flash etc.
                                            Opened it up and disconnected the main board from the power board by removing the connecting ribbon cable with the hope of getting either a 'no backlight' or a 'working backlight' but got neither,i just got a blinking backlight that turned on and off randomly...
                                            07-25-2022, 01:46 PM
                                          • 7ony
                                            Samsung plasma - flashing standby light
                                            by 7ony
                                            The TV is a 2013 Samsung plasma, model # PN60F5300AFXZA.
                                            Snagged it up in non-working condition a couple years ago. Previous owner said that sometimes he could get it to come on after repeated tries but other than that he couldn't get it to turn on.
                                            Personally I haven't been able to get it to turn on at all. The standby light comes on solid when plugged in, but pressing the power button results in the standby light flashing once every 4 or so seconds. No "click" noises, no light from the panel at all. Just the flashing standby light.
                                            No visible...
                                            08-31-2020, 05:18 PM
                                          • esqmooo
                                            HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
                                            by esqmooo
                                            Hello everyone.
                                            This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
                                            Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
                                            Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
                                            I tried long pressing on the power button, after several seconds it would go off then when the button is released...
                                            03-11-2025, 03:57 PM
