Sony KDL-65W850A Dead
  • kevinm34232
    • May 2012
    • 1884
    Re: Sony KDL-65W850A Dead
    I decided to go down to the LEDs.. This is different than ones I have seen before.
    There are 4 strips of 65 LEDs, 2 on each side.
    Each strip seems to have 5 sets of 13 LEDs, as the A and C reverse after each 13.
    There are 10 wires in the harness going to each strip.
    What's the best way to test these?? Testing each LED in diode mode with my DMM seems to give good readings but they don't light up..
    • kevinm34232
      • May 2012
      • 1884
      Can really use some help with testing these LEDs while I have the panel apart.. As I said, each strip has 5 "sets" of 13 LEDs. There is a common "+" for all 5 sets, but each "-" is independent of each other.
      See photo with the "+" test point, and the 3 "-" test points, there are 2 more sets of 13 to the right that are not in the picture.
      I am not sure how to test these, I've opened up 2 LEDs already trying to figure it out.
      I tested each LED in diode mode and all seemed good, I really would like to light them up..
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        #83
        Here's a link to a video and I know that ReeceyBurger123 also has one one Youtube.
        https://www.youtube.com/watch?v=eEJoPCa7Kt0
          'I tested each LED in diode mode and all seemed good' What does it show on the meter? 0.75. 3, 6?
          • kevinm34232
            • May 2012
            • 1884
            Originally posted by budm
            'i tested each led in diode mode and all seemed good' what does it show on the meter? 0.75. 3, 6?
            0.75 - 0.76
            Why are these reading like diodes, and not lighting up the diodes like the other strips I have?? Are these in parallel?
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              #86
              You said in an earlier post that you had a power supply so if you consider that each led has approximately 3.5V across it then to test 2 leds = 7V. Keep the current limit low say at 100mA to start with. Once you know what voltage and current is required to drive two leds brightly you can increase the voltage in proportionally to the number of leds you wish to test at a time.
              • kevinm34232
                • May 2012
                • 1884
                All other strips I have are in series, so they will light up with the DMM. These will not light up one at a time. I am confused by how they are wired, a common positive feed for all 65, but different negative for each set of 13.
                I don't know where to place the leads? This is how I opened 2 of them already.
                Can I hook my PS to the common +. and one of the - test points for the 13 LEDs?
                Is it going be set to 3V with higher current, or 3x13V like they were in series?
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  #88
                  Diah is the man to ask as he seems to have a lot of knowledge of LED's. What are the part numbers on the strips. That could help him.
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    #89
                    I can't see why you can't use your power supply and quickly touch 3V across one of the leds to see the results. Not a fast test but if it works you can test all the leds.
                    • kevinm34232
                      • May 2012
                      • 1884
                      I will try it again.. So set the PS to 3V and 100 mA?
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        #91
                        I feel that's a safe starting point. The led may come on but dim in which case increase the current limit slowly.
                          Originally posted by kevinm34232
                          0.75 - 0.76
                          You are reading the Vf of the protection diode which is in parallel with the LED/s.
                          Vf of single white LED is around 3V, dual LED will be around 6V.
                          Reverse your probe and test them again.
                          BTW, your meter may not have Voltage to test dual LEDs.
                          • kevinm34232
                            • May 2012
                            • 1884
                            So I may need to test each diode at 6V?
                            "BTW, your meter may not have Voltage to test dual LEDs."
                            My meter will just barely lights a regular LED..
                              First you need to get the correct ANODE/CATHODE pin first, so try using your meter in diode mode the establish the correct pin first, if you hook up the 3V or 6V wrong you can damage the protection diode and shorted it out.
                              The good LED in one way should show 0.6~0.7V (Vf of the protection Diode), and 3V (Vf of single white diode, or two LEDs in parallel), or 6V for dual LED (LEDs in series) in another way.
                              This is why it is important to use current limiter power supply in case you apply the Voltage with wrong polarity to the LED with built-in protection diode.
                              • kevinm34232
                                • May 2012
                                • 1884
                                With the DMM, the LEDs read 0.75V with black on the Anaode and Red on Cathode. So now what do I do?
                                  Reverse the leads and see what you get.
                                  PDF of single LED with protection diode.
                                  • kevinm34232
                                    • May 2012
                                    • 1884
                                    Reversing leads I get 0L, that's where on the other strips it would usually light up the LED.
                                      So whe you siad when the LED lights up, what does it show on the meter then? No way the white LED will light up and show 0.7V on the meter in diode mode.
                                      • kevinm34232
                                        • May 2012
                                        • 1884
                                        They do not light up either way I place the leads on this TV's LEDs. It just reads like a standard diode.
                                        I am saying that on the other LED strips I have worked on from other TVs, it would light up the LED (and also show 0L) with the leads one way, and show 0L the other way with no light. I would never get the usual diode reading.
                                        I cannot get these to light up at all with the DMM, and I'm unsure how to do it safely with the bench PS.
                                          OK, it shows 0.7V, you are reading the Vf of the protection diode, that means the polarity of the LED will be opposite of what you are probing,
                                          I.E. Red probe on one pin (called it pin 1), black probe on another pin (called it pin 2) the meter shows 0.7V. That means pin 1 is the CATHODE of the LED, PIN 2 is the ANODE of the LED.
                                          So apply 3V 100mA in that polarity, it should light up the LED, if not it may be dual LEDs in series, then you just have to turn up the Voltage slowly. Try that on the good LED.
                                          • thstuff
                                            Sony OLED XR-77A80J - Initially dead, now 4 Flashes
                                            by thstuff
                                            A) TV initially dead
                                            B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
                                            C) Was able to perform a Reset from Settings menu and completed out of box configuration.
                                            D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
                                            E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
                                            12-26-2024, 09:10 PM
                                          • bohaboha
                                            SONY KDL-46R473A ALMOST DEAD NO STB
                                            by bohaboha
                                            Hello to everyone in this wonderful forum.
                                            I have this SONY LCD TV KDL_46R473a
                                            PSU GL5 APS350 :1-888-122- 12
                                            MAINBOARD FY13_EU IP-012C101-4010
                                            black screen ,no STB no life almost death.
                                            on PS all the required volts are present 394V on the main cap and those on cold side 12.41V,3.45 and 3.45 are on
                                            Also 3,5,and 12v are on.
                                            nothing happens if i disconnect the PSU from the mainboard as on Samsung because here i think the mainboard gives the signal to the ps.
                                            don't know what to do next all suggestions and advice are very welcome​...
                                            04-24-2025, 04:40 PM
                                          • Talyn
                                            Sony 55W905 dead
                                            by Talyn
                                            My Sony W905 started to turn itself off an on every few minutes and blinking 8 times red in standby. A few minutes later the tv was completely dead.
                                            I can only hear the click of the PSU when attaching/detaching the power cable. No standby LED.
                                            Any advice? Thanks!
                                            04-15-2024, 08:14 AM
                                          • mrsith
                                            Sony KDL-55W755C - Dead
                                            by mrsith
                                            Hello again lifesavers.
                                            I have a KDL-55W755c that came in dead - not even standby light going on. Tested the power supply - all correct. Tested the output pins on the Led driver board (in which the power cord plugs in) - all seemed fine.
                                            I got a service manual for this model and tested the DC/DC converter by checking voltages on selected components. Every voltage was present where it should be. Service manual says that in this case a "Muffin" replacement is needed. This is the moment where I got stuck as I wasn't able to Google my way through it - till this day I...
                                            11-28-2022, 12:42 PM
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
