42LG60 powering up problems
  • anna1980
    • Mar 2016
    • 40
    • holland
    I just got some problems with my 42LG60 and I cant seem to find the problem
    When plugged in (after not using it some time) it turns on. Backlight turns on and image shows up. When turning it off and on. Nothing happens. It looks like some kind of reboot loop (red ring/white ring)
    so I took the service manual.
    Powerboard check ( EAY41971801 )
    Step 1. Check 5v line. Check okay
    Step 2. I connected a 10k resistor to 5v and power and checked the 5v, 12v and 16.5 v
    the 5v line is okay; so is the 12v line
    But the 16,5v line is low, about 14.68V
    Step 2. Connecting a jumper wire for the backlight.
    According to the servicemanual the backlight should turn on/off 4 times and than quit. Mines keep on blinking.
    16v keeps jumping from 10-14 volts and the 12v lines jumps from 11-12
    When disconnecting the jumper wire. The voltages keep jumping.
    I already replaced the caps on de powerboard but that doesn't seem to help
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: 42LG60 powering up problems
    Heat Psu see if it helps the issue.
    • anna1980
      • Mar 2016
      • 40
      • holland
      You mean the entire powerboard, or just parts of it
      Before replace the caps on the right side I heated them with a hairdryer. But that didn't seem to work
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Does it say on the PSU board what current the 16V line supplies and if so could you load it up and see if it still jumps around and if so I would suspect the PSU. Just a thought.
        • anna1980
          • Mar 2016
          • 40
          • holland
          Yes I tried meassuring the current. It really jumps up and down.
          But in this case the tv would start
          But I could have done it wrong. When the TV started fine :
          multimeter red probe on the 16v line
          black probe on the chassis.
          Sometime sparks were flying between the black probe and the chassis.
          Ofcourse the tv reboots at that moment
          • anna1980
            • Mar 2016
            • 40
            • holland
            I have noticed something weird.
            When heating the entire psu, the tv doesn't reboot or between the reboots there is more time. But also the backlight/sound doesn't come on.
            The ledring just lights up white
            • Diah
              • Feb 2013
              • 6594
              since you have PS ON and PWB working , just delay at boot loop, its not PWB,
              try to reset the TV to default Factory and check if it make delay again, also if there any update to firmware do it.
              also read page 17 at Service M. if you have one voltage more or less than its will delay and effect on image start.
              • anna1980
                • Mar 2016
                • 40
                • holland
                @Diah.
                Vielen Dank für Ihre Hilfe (thank you very much) I feel really stupid but when I updated the software and gave it a factory reset everything worked. Ofcourse changing the capacitors isn't bad anyway but your solution seems te be the answer
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  Sound like good news. Well done Diah,
                  • cubytus
                    Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                    by cubytus
                    Hi to all,
                    I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                    I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                    Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                    01-10-2024, 01:26 AM
                  • otaku_nut
                    Vizio E701i-A3 fixed but now has red vertical line
                    by otaku_nut
                    Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
                    08-19-2025, 06:11 PM
                  • TrueSword88
                    Kogan - KALED65XU9220STB - Blue Vertical Line
                    by TrueSword88
                    Hi all.
                    I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                    The line just happens to coincide with the end of COF and start of the next COF (attached).
                    The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                    Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                    Hoping to fix...
                    05-05-2023, 04:28 PM
                  • jean luc ferre
                    laptop hp g72 b52sf screen problems
                    by jean luc ferre
                    on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                    the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                    i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                    i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                    06-07-2025, 03:27 PM
                  • FALKLAN
                    Running Line Voltage and Integrating LED Pods - Automotive
                    by FALKLAN
                    Howdy everyone! I hope all is well where ever you are!
                    I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
                    I am uncertain how to convert this line into a switched 12v output line for the LED pods....
                    02-05-2025, 12:30 AM
