LG 60pk750 problems.
  • jbates58
    • Mar 2016
    • 7
    hello all.
    i have a LG 60pk750 plasma. and it has just developed the usual works for 10-20min then turns off and the stby light is fixed on and it wont turn back on.
    it has the Eay60968901 power board, and as far as i can tell, all the t.p voltages are spot on when its operating.
    i have looked around and found a few sited selling repair kits, and i have tested the componants that they offer on the repair (although in-circuit, im yet to de-solder them and test them) but they all test out.
    the common parts i have found that need replacing in these kits are
    IC701
    R108
    R109
    R110
    R111
    R112
    R113
    R296 (i think i have the number correct - the big ceramic one in the top right corner)
    R297 (i think i have the number correct - the big ceramic one in the top right corner)
    R298 (i think i have the number correct - the big ceramic one in the top right corner)
    and they all check out. i cant test the ic, as i dont know how. but could it be the issue? i will pull all the resistors and test and replace them as i can source them from my local electronics store easily enough.
    any suggestions?
    Jason
  • jbates58
    • Mar 2016
    • 7
    Re: LG 60pk750 problems.
    Anybody have any suggestions?
    Jason
    • C_nuggz
      • Feb 2016
      • 9
      • United states
      Have you checked for dry solder joints on the power supply? I had a similar problem to yours with my 50pj350 lg plasma and it turned out to be a few dry solder joints causing the problem.
      • jbates58
        • Mar 2016
        • 7
        no i havent. thats alot of joints to check. was kind of wondering if it likley to be any of the componants i listed.
        Jason
        • jbates58
          • Mar 2016
          • 7
          can anybody help? i would like to know if it is likley to be these components, so i can replace them. how can i go about testing the ic? if i get one from my local electronics store, will it be programmed the same as the one thats in there? or will it need to be specially programmed?
          Jason
          • Redjess
            • Feb 2016
            • 54
            • Usa
            Ive got a 60pk550 im parting, screen no good, but all others are good, i bought extra too.
            • jbates58
              • Mar 2016
              • 7
              ok, so i have pulled all the resistors mentioned above, and checked them. they are all sweet. so the only thing left is the IC. is that something thats likley to fail? what else can i look for?
              and thanks @Redjess, but im located in aus. so i think that postage would be a killer.
              but we will see how we go.
              Jason
              • jbates58
                • Mar 2016
                • 7
                is anyone able to provide any insight? do i need to supply more info? am i missing something ?
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  resolder any components that are attached too heat sink as these seem to go dry jointed etc over time. even if they look good just add some fresh solder for peace of mind and retest the tv.
                  • biragalliani
                    • Sep 2018
                    Hello everyone one. I have the same model and I was watching tv and all the sudden my image went out and it sounded like demons were speaking out of my tv. The tv turns on and off but I can get any image. Can someone help me?
                    • Andrew F. Ali
                      • Jan 2014
                      • 2450
                      • Trinidad & Tobago
                      You said you can turn the TV on and off. What exactly does that mean? Do you mean then have audio but no picture? You are able to manipulate the Menu to change the inputs? OR are you just hearing a 'click' when the power button is pressed and then another 'click' a while after?
                      Did you accidentally double post on another thread? Why not open your own thread to make it easier?
                      • chth96
                        by chth96
                        03-09-2024, 10:03 PM
                      • chth96
                        How Can I test PWM DM0365R?
                        by chth96
                        Hello
                        I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                        So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                        I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                        I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                        06-18-2025, 04:14 PM
                      • chronic519
                        Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                        by chronic519
                        Hello.
                        GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                        Found issue with a RAM block
                        Replaced, green lines gone.
                        Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                        Used a good card to test and same results low errors 32+.
                        I am just search for some form of command to do a full test on the GPU.
                        I just ran the mats command with my good GPU and passed after roughly 40 min.
                        The repaired one, ran...
                        05-20-2025, 07:56 PM
                      • hemant_2222
                        Yamaha 2064 No sound but Test audio working
                        by hemant_2222
                        Hello Guys,
                        Greetings!
                        Hope you all are doing well.
                        I am looking for suggestion on Yamaha 2064. The problem with this receiver is that it has no sound however when the test tones are activated it does outputs from all the speakers. It is working in two channel stereo mode but when you select other sound modes, it doesn't. The last time it had a problem, I had replaced the DAC
                        PCM1681DBQR - IC263 and it worked fine.
                        Other issue with it is one of the STK ICs is getting more heated then the other one but that can be looked at later.
                        11-01-2025, 11:20 PM
                      • alltvrepairs
                        Lg TCon test pins for screen test
                        by alltvrepairs
                        i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                        Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                        Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                        Appreciate your help....
                        06-13-2025, 06:33 AM
