How to enter the service menu? 42Pf5320/10 Philips
  • ducky29
    • Dec 2015
    • 369
    • Europe
    42Pf5320/10 Philips
    When I do a search , it only searches for channels in 2 out of 3 Bands.I thought it might be a tuner problem.I replaced the tuner but it didn't fix the problem.I think it can be solved through the service menu.So If I can get some about getting into the service menu, or maybe someone who had a similar experience, that would be awsome.
    Thank you!
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: How to enter the service menu? 42Pf5320/10 Philips
    It may tell you in the manual
    • ducky29
      • Dec 2015
      • 369
      • Europe
      Thanks a lot! I will try tomorrow.Hopefully it works.
      • ducky29
        • Dec 2015
        • 369
        • Europe
        I was able to get into the service mode but unfortunately I could not fix the problem.
          LCD LED TV Service Menu Codes
          TCL LED TV Service Menu Code
          LG LED TV Service Menu Code
          10-31-2024, 03:58 AM
        • tusiime
          How to access Vizio m652i-b2 service menu
          by tusiime
          The current main board on my Vizio m652i-b2 only has 1 of 4 HDMI ports working. Also, the coaxial port is not working.
          So I ordered a replacement board. It boots up the tv, but the display is dark in areas, colors are off, etc. I have seen information online that a setting in the service menu may need to be adjusted. Have tried many ways to access the service menu using remote codes, but none work.
          Can someone here provide the confirmed method for accessing the service menu on this tv? Thanks in advance!
          09-15-2023, 09:57 AM
        • alltvrepairs
          Jvc Lt-65VU3000 reduce backlight from service menu
          by alltvrepairs
          I have just replaced led set of this vestel tv due to age.
          I would like to reduce backlight from service mode. I have tried menu 4725 but in the menu i can't change anything.
          Any help pls? I don't want to change from electronics inverter feedback resistor ideally.
          Thanks again....
          09-20-2025, 05:03 AM
        • sohail5307
          I need how to open this Dell service menu option in dell latitude e6420
          by sohail5307
          I need to open service menu of Dell laptops like image in attachment
          Ignore my English
          I want beacause i flashed mec5055 using rt809h now it's does not have service tag, but when I install service using F2 in bios setup after save service tag and press disable manufacturing mode using alt+f then battery chagring is permanently disabled. I want to resolve this problem...
          01-13-2023, 05:56 AM
        • yoritomo
          Philips 40PFK4100/12 CI key fail error
          by yoritomo
          TV Philips 40PFK4100/12
          Chassis TPN15.E LA
          Hello everyone.
          I am facing a red message above the screen permanently, also the image is greyed and the TV is unusable as is in any sources.
          Of course I tried everything basic or a bit advanced, so I updated the firmware to version 2.550 which did not resolve the problem.
          Accessing the secret menu by I have access to 3 interesting parameters regarding this issue
          -DRM Warning
          -CIPlus Query
          -CIPlus update
          Obviously I tried to set DRM warning to OFF but this don't...
          08-17-2025, 12:27 PM
