Picture fault on le40m86
  • Rickig
    • Mar 2015
    • 112
    • England
    Hi guys.
    I'm probably answering my own question here but I have the above mentioned set that had the clicking fault. I replaced the bad caps and the tv powered up. I noticed however the freeview wasn't working so I removed the main AV and replaced the eeprom.
    Fired tv back up and now the picture is all funny, pink and purple etc. So I immediately thought tcon gone down t400hw01 as it suffers a similar fault.
    Replaced tcon. Fault still there, tried new main AV, fault still there, tried a different psu and fault still there.
    Just seems odd that it was fine until I changed the eeprom. I even tried another eeprom and fault still there.
    Any ideas? Or shall I concede and say it's the panel?
    Thanks in advance
    Re: Picture fault on le40m86
    ' I replaced the bad caps and the tv powered up. I noticed however the freeview wasn't working so I removed the main AV and replaced the eeprom. ' So before replacing the EEPROM, do you get good pictures using other Video sources?
    • Rickig
      • Mar 2015
      • 112
      • England
      Yes picture was fine. That's why I'm scratching my head.
      • Rickig
        • Mar 2015
        • 112
        • England
        Here's a pic
          May be you have to get into the service menu setup screen (MUTE, 1. 8, 2, POWER) and check the panel setup, LVDS signal format, etc. May be the EEPROM was not made for that TV chassis.
          It has wrong GAMMA Voltages right now.
          • Rickig
            • Mar 2015
            • 112
            • England
            Pm me your number talk me through it. But I've tried 2 other good main boards
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              Hello Rickig,
              Can you post a picture for us to see how it is now.
              You beat me to it. Sorry.
              • Rickig
                • Mar 2015
                • 112
                • England
                Tv clicks to come on as soon as you hit 1. I normally do info menu mute power. Is that same?
                • dick_barton
                  • Aug 2015
                  • 6642
                  • Wales
                  The picture looks similar to what happened to me recently when I changed a mainboard. I had to replace the SPI chip from the old board onto the new board then everything was back to normal.
                    The Mute, 1, 8, 2, power may not work with your model I am not sure.
                    I do not expect the TV to come on when you hit '1'.
                    It should come on only after you enter the last button which is the power button.
                    BTW, the panel cannot cause that off color like that.
                    • Rickig
                      • Mar 2015
                      • 112
                      • England
                      It's the original board fitted, tried 2 others. Tried a tcon tried a power board.
                      • dick_barton
                        • Aug 2015
                        • 6642
                        • Wales
                        That's the code for my Samsung. Just checked.
                          Thanks for that info.
                          • Kilroys
                            • Feb 2014
                            • 70
                            • Sweden
                            Option codes
                              Thanks!
                              No LVDS codes for these series?
                              • Electronic Handyman
                                • Apr 2016
                                • 58
                                In a lot of cases the Eprom has to be programmed for the board and that could be your issue.Some places sell the Eproms already programmed for the set you need it for.
                                • dick_barton
                                  • Aug 2015
                                  • 6642
                                  • Wales
                                  Have you still got your original main board and the original EEprom you could solder back in place?
                                    To get into the service menu press, from standby mode, Info Menu Mute Power
                                    Only for European/Australian Samsung sets. US sets use Mute 1 8 2 Power.
                                    • Tr0ll
                                      by Tr0ll
                                      Original T-con:
                                      First replacement T-con:
                                      10-07-2023, 07:48 PM
                                    • JJAAMM
                                      by JJAAMM
                                      Problem
                                      07-06-2023, 06:01 AM
                                    • SidneyCanadas
                                      93C46 and 93C56 EEPROM
                                      by SidneyCanadas
                                      I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
                                      https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
                                      Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
                                      06-14-2023, 01:16 PM
                                    • TR103
                                      by TR103
                                      - it keeps rebooting
                                      01-22-2025, 04:12 PM
                                    • NYKing
                                      Hisense TV 32D33 - Replaced EEPROM, now menus have no text
                                      by NYKing
                                      The TV initially had a steady (not flashing) red standby light but did not turn on when power button was pressed. I tried all the usual “fixes” but nothing worked. TV would not turn on. After researching the issue, I concluded the cause was a bad EEPROM chip. I ordered the appropriate chip from ShopJimmy:
                                      https://www.shopjimmy.com/hisense-32...hoCOcUQAvD_BwE
                                      I took off the old chip using my hot air station and soldered on the new chip. I tested...
                                      10-07-2021, 05:06 PM
