TC-P50VT20 10 Blink Code
Re: TC-P50VT20 10 Blink Code
Page 36, see if you can make sense of that.
Also hook everything back up then try this.
To force the TV to display a white screen:
1. Unplug the TV.
2. With P6 and P7 disconnected, disconnect D5 from the from the D/A board.
3. Plug in the TV.
4. Now the TV turns on by itself with a white screen
see what happensComment
quite big files but detailed. links
1.https://drive.google.com/file/d/0B23...ew?usp=sharing
2.https://drive.google.com/file/d/0B23...ew?usp=sharing
3.https://drive.google.com/file/d/0B23...ew?usp=sharing
4.https://drive.google.com/file/d/0B23...ew?usp=sharingComment
running out of brain power. connect p6, p7, have D3 D5 disconnected, hoping for it to give white screen.Comment
If not then remove that link, put it all back together, disconnect that small tuner board above the A board and turn it on.
If that fails then I think go back to that p36 where it talks about checking the F15v and 15V.
The F15V is the standby 15V which is generated first and then when the set fires up the P15v should get switched on.
was the P board one of the many boards replaced?
I'll wait until you try D3 and then disconnecting the tuner module.
After that I'm too tired to think but someone in the UK might be around to give it a shot.
It should be possible to isolate the A board and get this to fire up, that has me curiousComment
it and tried, no white. all wires put back on and tested without the tuner card, still same issues.When it makes a click after pwer on, the green lights on SS and SC fades soon away. The power board is also changed. Probably old boards work also. I can try and have tried different combination of P-board,A-board and D board.so far no luck.Comment
Well , I don't know if this will prove anything at this point but try this.
disconnect sc2, Sc20, ss11, p35, the 2 white ribbons that go from the D-board to the c-buffers.
turn on and see if it 10 blinks, don't reconnect p35 sc2 or ss11 until there's no residual voltage present on those for risk of damaging a board or panel.Comment
still 10 blinks. Does it indicate more like A-board, which might have defective already before mounted? Or two board at once. If only SS board would be broken then white screen should appear to the screen, isnt it? Ok, talk futher another day. Good night and much appreciationComment
Might be time to confirm the voltages F15v and 15V. Could mean one of the boards received is also faulty.
With just the P,D and A connected it's one of those I feelComment
maybe this manual is close enough i got the link from another forum
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by cheeky2For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...01-08-2024, 05:56 AM - Loading...
