Post The Led Backlights Your Fixing Here.
  • comptek
    • Aug 2013
    • 606
    • uk
    #81
    Re: Post The Led Backlights Your Fixing Here.
    well flocko says
    If they are the large LG lens Type they will not light with meter in diode mode? they run at 5.5-6.00 v
    so if this was my set i would probs take a chance.
    2 leds did glow with my fluke meter and then retested with 3 x AA cells and even the ones that glowed looked odd they seem to be dual led in 1 package as one lit on left hand side and the other on the right so i guess the 2 glowed as only one was working in each led package (if you get what i mean)
    • flocko
      • Nov 2012
      • 1121
      • uk
      #82
      The good news is you have worked out how to test the LEDs. The not so good news is I am out of 32"strips only 42" +49" left in stock. but still have some LEDs in stack repair kits
      • comptek
        • Aug 2013
        • 606
        • uk
        #83
        oh well thanks Flocko i will order some off of Aliexpress i assume 6v 3030 leds wil be ok ?
        thanks Again Flocko
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          #84
          have you measured the led size on your strip? aliexpress have so many too choose from.
          • comptek
            • Aug 2013
            • 606
            • uk
            #85
            yes it looks like 3mm x 3mm
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              #86
              At that price they are cheaper than led strips but harder too change i guess, but hey its worth just trying a couple and powering the set up and see what the colour/brightness match is like.
              • comptek
                • Aug 2013
                • 606
                • uk
                #87
                hi Vince i have ordered 50 theres only 2 out of the 18 leds that actualy half work theyre dual chip led's so i dont think matching will help much im aiming to replace all
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  #88
                  dual chip? never heard of that in the diagram there two diodes in each of the leds that you have ordered so is there two leds in one sorry for questions as never heard of dual chip leds.
                  • comptek
                    • Aug 2013
                    • 606
                    • uk
                    #89
                    on the 2 leds i checked that half work one lights up on left side and the other led lights up on the right side and you can see its half of the led, yes as it seems there is 2 led chips in each led assuming this is how they get the 6v in one package ?
                    • flocko
                      • Nov 2012
                      • 1121
                      • uk
                      #90
                      A lot of edge lite strips also have the two LEDs in one case,and also run at 5.5-6.00v but have an oblong case. and can be hard check as you need to just have a large enough voltage to turn them on without it blinding you
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        #91
                        Thanks that makes sence too me now
                        • comptek
                          • Aug 2013
                          • 606
                          • uk
                          #92
                          Vinceroger69
                          when you look at the mains or high power COB LED (chip on board) there are loads of them if youre into stuff like that lookup BIGCLIVE on youtube he does alot of teardown stuff >>>>
                          https://www.youtube.com/watch?v=mZZbj-DNk7M
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            • uk
                            #93
                            Vinceroger69
                            Thanks for the youtube link.
                              They make DUAL-LED in one package in many form factors with LEDs in series (6Vf rating due to two white LEDs is series), they also make DUAL-LED connected in parallel, Vf 3V.
                              See example PDF.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                #95
                                See example PDF.
                                Thanks budm.
                                • comptek
                                  • Aug 2013
                                  • 606
                                  • uk
                                  #96
                                  youre welcome i have watched all of his vids the one about a jewel thief is good simple to make too
                                  • comptek
                                    • Aug 2013
                                    • 606
                                    • uk
                                    #97
                                    See example PDF.
                                    thanks Budm very interesting
                                    • sleeper123
                                      • Aug 2016
                                      • 17
                                      Just got done replacing 2 LEDs in a vizio e470i-a0. My first tv repair.
                                      TVs fixed:
                                      Vizio E470i-A0
                                      LG 50PT350
                                      Vizio E470i-A0
                                      LG 47LN5400
                                      LG 47LN5750
                                      Vizio E470i-A0
                                      Vizio VP322
                                      Magnavox 40ME325V/F7
                                      Emerson LF501EM5F
                                      • sleeper123
                                        • Aug 2016
                                        • 17
                                        Wouldn't let me attach both pictures.
                                        TVs fixed:
                                        Vizio E470i-A0
                                        LG 50PT350
                                        Vizio E470i-A0
                                        LG 47LN5400
                                        LG 47LN5750
                                        Vizio E470i-A0
                                        Vizio VP322
                                        Emerson LF501EM5F
                                        • ReeceyBurger123
                                          Never Give Up !
                                          • May 2014
                                          • 7325
                                          • Britain
                                          #100
                                          Good work
                                          • Pipolups
                                            Corsair K70 LUX RGB dying LEDs
                                            by Pipolups
                                            Hi there !
                                            I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                                            Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                                            10-08-2024, 11:58 AM
                                          • TrisHCl
                                            LED TV Boot loop - UE40F6500SB
                                            by TrisHCl
                                            First post...
                                            I have this TV, which was working, then suddenly would not turn on. It would get the clicking relay then flash up the screen for less than a second, off for a second then on again. Removing the plug the relay continues to click on and off for a few cycles, which I don't think it did before.
                                            Left it a few months, then finally got round to taking the back off, and it worked as it should. So I tested various bits and all was well. Then turned it on again, and back to the clicking relay.
                                            I disconnected the main board from the power...
                                            02-06-2025, 08:42 AM
                                          • max789
                                            Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                                            by max789
                                            Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                                            I made the following tests:
                                            1. Disconnected the main board from Power Board = backlight works.
                                            2. Connected the main board and disconnected the T-Con = backlights does not work.
                                            So I ordered a main board from Ebay also BN41-02156A but from...
                                            01-18-2024, 06:56 AM
                                          • bpcannan
                                            VIZIO M557-G0: Backlights or ???
                                            by bpcannan
                                            'Morning,
                                            I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
                                            Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
                                            I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
                                            I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate...
                                            10-29-2023, 06:36 AM
                                          • jesterace
                                            Samsung UE49MU6400 acts dead until disconnecting backlights, then works.
                                            by jesterace
                                            Hi everyone I have this TV which was dead one day when I tried to turn it on. I've had the cover off and there was just a pulsating/electrical clicking/ticking noise from the PSU. I disconnected the mainboard as sometimes this works to just fire it up with backlights on? That didn't help. Same noise. Then I disconnected the backlight cable from the PSU and the TV came alive. It appeared to respond to the remote and i'm pretty sure it's fully operational when there is no backlight connected.
                                            However, I am in a dilemma.
                                            I tested the backlight outputs with the lights disconnected...
                                            10-20-2024, 10:15 AM
