Spectre E325BV no power.
Re: Spectre E325BV no power.
Originally posted by dick_barton View PostBecause I don't have the schematic for your power supply, looking at the pdf for the IC I posted earlier indicates that there are resistors up to the +ve supply of the large capacitor.
What voltage are you getting across the two terminals of that large capacitor?.
191v.
Originally posted by dick_barton View PostTouché. I think there are two resistors marked 512 in series coming from pin 8 of the IC possibly going to the +Ve of the bridge rectifier. What do they measure?
They both measure 5000 ohm
its pretty much 4 diodes and its used to get AC current to change into DC current.
Its actually really cool how it works. Makes a lot of sense once you understand it.
Also here is one option which would possibly be worth it to learn. Buy a new board since they are cheap, keep trouble shooting yours in the mean time, but once you get the new board, plug it in make sure it works, and then use it as a guide and see what you should be getting for your readings on all of your components.
Might make things a bit easier.
Check PC1, are any of those legs showing any ohms to one another?
Originally posted by dick_barton View PostWhat part numbers are printed on Q2 & Q4 on the underside of the board?
I don't see a bridge rectifier that looks like the image you posted. Sorry to be so useles.
I see something that traced to with a number KBL06. It has 4 leads and is screwed on to the heatsink.
The leads are labeled + AC -Last edited by Malachi; 04-16-2016, 09:11 AM.
The leads are labeled + AC -Willing to help but I'm no expert.
Out of curiosity if you place your negative lead on chassis and postive lead on the 5V stby pin then switch on the power do you get a voltage reading at switch on. It may well drop to 0v quickly but is it there when first powered up.Willing to help but I'm no expert.
No, I appreciate the PSU is not in the TV. But can you measure the voltage when you switch the power on for the PSU at the wall socket outlet.Last edited by dick_barton; 04-16-2016, 09:34 AM.Willing to help but I'm no expert.
