Spectre E325BV no power.
  • Malachi
    • Dec 2015
    • 1077
    • Usa
    Re: Spectre E325BV no power.
    I don't see a board marked IC1
    • Malachi
      • Dec 2015
      • 1077
      • Usa
      Diodes on the heatsink? The 3 legged components?
        It is on the bottom side of the board.
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          Its the 8 legged device (IC) at the top of the board.
          Courtesy of Shopjimmy
            Yes, D2, D3.
            Check for LOW RESISTANCE between the center leg and either the two outter legs.
            • Malachi
              • Dec 2015
              • 1077
              • Usa
              #26
              Originally posted by dick_barton
              What is the number printed on the IC on the underside of the board marked as IC1
              Dang, with my readers on and jewelers loops I can barely see it.
              I think it's GR8876A
              BC010
              • Malachi
                • Dec 2015
                • 1077
                • Usa
                #27
                Originally posted by budm
                Yes, D2, D3.
                Does it matter which lead goes where? Black in the middle?
                  If it is shorted out then it does matter, we are checking resistance so set the meter to Ohm mode.
                  • dick_barton
                    • Aug 2015
                    • 6642
                    • Wales
                    #29
                    That's the right number. Your circuit should not be to dissimilar to the schematic. Maybe changing the capacitor budm asked you to heatup may get you going. You need to check you have voltages on Pin6 & 8
                    Data sheet
                    • Malachi
                      • Dec 2015
                      • 1077
                      • Usa
                      #30
                      D2 with the black lead in the middle reads 3.4K Ohm.
                      D3 1.9K
                        D3 1.9K
                        They are not shorted out, was looking for <10 Ohms or so.
                        • Malachi
                          • Dec 2015
                          • 1077
                          • Usa
                          #32
                          Thanks. What's next?
                          • dick_barton
                            • Aug 2015
                            • 6642
                            • Wales
                            #33
                            What were the voltages read on IC1?
                            • Malachi
                              • Dec 2015
                              • 1077
                              • Usa
                              #34
                              I didn't check. No one asked and I didn't know. Lol.
                              One of the contacts read 70v, another -80v. How can it be negative?
                              • dick_barton
                                • Aug 2015
                                • 6642
                                • Wales
                                #35
                                Post #29 but I think you were having a lot of questions fired at you at the time
                                • Malachi
                                  • Dec 2015
                                  • 1077
                                  • Usa
                                  #36
                                  You are right. Sorry dick. The pins aren't labeled that I can see.
                                  Most of them have a negative reading. Only one has a +70v. The rest -80 or 0.
                                  • dick_barton
                                    • Aug 2015
                                    • 6642
                                    • Wales
                                    #37
                                    Did you connect your negative lead of your meter to the negative lead of the large capacitor and not chassis.
                                    • Malachi
                                      • Dec 2015
                                      • 1077
                                      • Usa
                                      #38
                                      No, since the board is off the the TV and laying on a piece of carboard, I put my black lead on a spot labeled GND.
                                      I'll try again using your suggestion.
                                      • Malachi
                                        • Dec 2015
                                        • 1077
                                        • Usa
                                        #39
                                        Doing it that way, only one pin gave a reading of 2.7V.
                                        • dick_barton
                                          • Aug 2015
                                          • 6642
                                          • Wales
                                          #40
                                          Because I don't have the schematic for your power supply, looking at the pdf for the IC I posted earlier indicates that there are resistors up to the +ve supply of the large capacitor.
                                          What voltage are you getting across the two terminals of that large capacitor?
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • beetle1303
                                            Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                            by beetle1303
                                            I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                            On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                            01-13-2025, 08:49 PM
                                          • chopduel
                                            Bad mains power causing TV malfunctions?
                                            by chopduel
                                            I've been living in the same apartment for about 5 years now, and moved into it with my old Samsung plasma TV (PS51F5500).
                                            Ever since we've moved in, we would sometimes see strange power-cycling behavior. For example:
                                            • TV would randomly turn off then back on.
                                            • TV would turn off and the LED light would blink for a while (over a minute sometimes) until eventually it went back to a regular off state and could be turned on
                                            • Sometimes it would require disconnecting the mains cord from the TV, waiting several minutes, then putting it back in and turning the TV back on. This had limited
                                            12-29-2024, 03:20 AM
