Spectre E325BV no power.
+ More Options
Posts
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    #41
    Re: Spectre E325BV no power.
    Originally posted by Malachi
    Doing it that way, only one pin gave a reading of 2.7V.
    Which pin?
    • Malachi
      • Dec 2015
      • 1077
      • Usa
      #42
      Originally posted by dick_barton
      Because I don't have the schematic for your power supply, looking at the pdf for the IC I posted earlier indicates that there are resistors up to the +ve supply of the large capacitor.
      What voltage are you getting across the two terminals of that large capacitor?
      My turn now. See post #15. .
      191v.
      • Malachi
        • Dec 2015
        • 1077
        • Usa
        #43
        Which pin?
        I don't know. They aren't labeled.
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          #44
          Touché. I think there are two resistors marked 512 in series coming from pin 8 of the IC possibly going to the +Ve of the bridge rectifier. What do they measure?
          • Malachi
            • Dec 2015
            • 1077
            • Usa
            #45
            Measure the voltage on them or the resistance?
            They both measure 5000 ohm
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              #46
              "I don't know. They aren't labeled"
              IC's normally have a dimple on the top. To the lefthand side of the dimple going anticlockwise gives you the pin numbers.
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                #47
                There doesn't seem to be a problem there then.
                • Malachi
                  • Dec 2015
                  • 1077
                  • Usa
                  #48
                  In that case pin 6 read 2.7v
                  • dick_barton
                    • Aug 2015
                    • 6642
                    • Wales
                    #49
                    Can you follow pin8 back and does it connect to the +Ve of the bridge rectifier?
                    • Malachi
                      • Dec 2015
                      • 1077
                      • Usa
                      #50
                      I can try when I get back home. Can you tell me what the bridge rectifier is?
                      • dick_barton
                        • Aug 2015
                        • 6642
                        • Wales
                        #51
                        Here's an image of one
                        + = Positive DC Terminal
                        - = Negative DC Terminal
                        ~ = AC input Terminal
                        The Positive and Negative terminals go to the large capacitor.
                        • Nick's Tvs
                          • Jan 2014
                          • 621
                          its pretty much 4 diodes and its used to get AC current to change into DC current.
                          Its actually really cool how it works. Makes a lot of sense once you understand it.
                          Also here is one option which would possibly be worth it to learn. Buy a new board since they are cheap, keep trouble shooting yours in the mean time, but once you get the new board, plug it in make sure it works, and then use it as a guide and see what you should be getting for your readings on all of your components.
                          Might make things a bit easier.
                          Check PC1, are any of those legs showing any ohms to one another?
                          • dick_barton
                            • Aug 2015
                            • 6642
                            • Wales
                            #53
                            What part numbers are printed on Q2 & Q4 on the underside of the board?
                            • Malachi
                              • Dec 2015
                              • 1077
                              • Usa
                              #54
                              BA2A9.
                              I don't see a bridge rectifier that looks like the image you posted. Sorry to be so useles.
                              I see something that traced to with a number KBL06. It has 4 leads and is screwed on to the heatsink.
                              The leads are labeled + AC -
                              • Malachi
                                • Dec 2015
                                • 1077
                                • Usa
                                #55
                                PC1 shows ohms as long as I check the the two on the same side. When I check across 0.L.
                                • dick_barton
                                  • Aug 2015
                                  • 6642
                                  • Wales
                                  #56
                                  BA2A9.
                                  That is the bridge rectifier. They come in many packages.
                                  • Malachi
                                    • Dec 2015
                                    • 1077
                                    • Usa
                                    #57
                                    Pin 8 traces to the + of the bridge rectifier.
                                    • dick_barton
                                      • Aug 2015
                                      • 6642
                                      • Wales
                                      #58
                                      Out of curiosity if you place your negative lead on chassis and postive lead on the 5V stby pin then switch on the power do you get a voltage reading at switch on. It may well drop to 0v quickly but is it there when first powered up.
                                      • Malachi
                                        • Dec 2015
                                        • 1077
                                        • Usa
                                        #59
                                        The psu is not in the TV but when it was it wouldn't switch on. No sign of life at all when pressing the power button, so I checked when plugging it in.
                                        • dick_barton
                                          • Aug 2015
                                          • 6642
                                          • Wales
                                          #60
                                          No, I appreciate the PSU is not in the TV. But can you measure the voltage when you switch the power on for the PSU at the wall socket outlet.
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • beetle1303
                                            Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                            by beetle1303
                                            I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                            On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                            01-13-2025, 08:49 PM
                                          • chopduel
                                            Bad mains power causing TV malfunctions?
                                            by chopduel
                                            I've been living in the same apartment for about 5 years now, and moved into it with my old Samsung plasma TV (PS51F5500).
                                            Ever since we've moved in, we would sometimes see strange power-cycling behavior. For example:
                                            • TV would randomly turn off then back on.
                                            • TV would turn off and the LED light would blink for a while (over a minute sometimes) until eventually it went back to a regular off state and could be turned on
                                            • Sometimes it would require disconnecting the mains cord from the TV, waiting several minutes, then putting it back in and turning the TV back on. This had limited
                                            12-29-2024, 03:20 AM
