Samsung LN46A650A1F LCD screen issue
+ More Options
Posts
  • ScHAmPi
    Samsung UE48JU7000 screen issue after backlight replacement
    by ScHAmPi
    Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
    I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...
    07-15-2024, 05:41 AM
  • Stanley1843
    by Stanley1843
    06-29-2024, 11:54 AM
  • Chrissygizmo
    by Chrissygizmo
    02-10-2025, 12:33 AM
  • Runlinc
    Samsung QE50Q60TAU - Horizontal screen lines
    by Runlinc
    Hi everyone, the tv was in a continuous reboot cycle. To get the best screen image i can I taped the VGH and VSS pins on the left side buffer board joining ribbon.
    I am left with a good image apart from the black horizontal lines that I cannot get rid of.
    I cannot find anything on the buffer boards that has shorted.
    Do you think there is anything i can do to eliminate the lines, or are they caused by an internal panel short and the image cannot be impoved.
    Many thanks for your assistance
    05-14-2024, 07:40 AM
  • Ancient1
    Strange LG TV issue : Image vertical lines in black screen
    by Ancient1
    Hi
    Asking for a friend.
    I'm used to black vertical line in otherwise good image - probable solution is a rubber to push and tighten the COFs bonding.
    but here its the opposite !
    TV has new T-con = same issue
    A missing panel voltage would have global effect
    So , what should one do ? how can I find where the fault is ?
    Thanks !...
    02-05-2025, 03:37 PM
