westinghouse DWM551Y1 no power
  • taft1957
    • Oct 2013
    • 95
    This set is completely dead, just solid red standby light. I replaced power supply, main board, and what do they call that small board with the eeprom on it? still no fix. Anyone have problems like this? anyone have a schematic for this tv, or just a fix, or a suggestion.
    Taft
  • taft1957
    • Oct 2013
    • 95
    Re: westinghouse DWM551Y1 no power
    does anyone have a service manual for this tv?
    • martyparish
      • Dec 2012
      • 313
      Can you upload pictures?
      Did you test the voltages on the power supply(old and new)?
      First thing I would check, is the STBY voltage correct. Then you can test the PSON lead to see if it changes when you hit power button.
      • taft1957
        • Oct 2013
        • 95
        I may have been thrown a curveball by receiving a defective new power supply. Even after replacing the main, and eeprom board? i just jumped the power on to 5 volts standby, and the 12 volt to backlight on Voltages were fluctuating up and down from 12 volts to 5 volts very erratic. I lifted TR1338 VLD-LEDTV1251-L7 that is the number on the part. not a location number. After I lifted it voltages all stabilized. I think I found my problem. anyone know where I can buy this part?
        Taft
          'TR1338 VLD-LEDTV1251-L7 ' we have no idea what that is. Where are the pictures? It sure does not sound like P/N of components to me.
          Some kind of transformer? Inductor? so when you lift it the drive circuit that drive this part may be bad so when you disconnected it the circuit no linger draw the current, so it may not be this part that is bad but the components that drive this part may be bad.
          We cannot do much until we get to see good clear pictures of what we are dealing with first.
            Is this your board?
            http://www.shopjimmy.com/seiki-890-p...upply-unit.htm
            Seiki/Element 890-PF0-5501 Power Supply.
            TR1338 VLD-LEDTV1251-L7, L7 looks to be designator for the part.
            Model number on the barcode sticker is 'VLD-LEDTV1251????'
            P/N for the board on the barcode sticker?
            • taft1957
              • Oct 2013
              • 95
              Yes that is my board?
              • taft1957
                • Oct 2013
                • 95
                I was hoping to buy the part and not the whole board.
                  So which part that you lifted off the board?
                  • taft1957
                    • Oct 2013
                    • 95
                    here are some pictures
                    • dick_barton
                      • Aug 2015
                      • 6642
                      • Wales
                      Hello Taft1957,
                      Your first post says you replaced the power supply so can't you take the transformer from the defunct psu?
                        That is not transformer, that is the inductor for the Boost converter for the LED sriver circuit, so when you remove it it is no longer connected to the power MOSFET that is used for driving the inductor. It will also show low DCR value which is normal.
                          Any Straight shot pictures of the bottom side of the board without the insulator sheet in place?
                          • taft1957
                            • Oct 2013
                            • 95
                            Stupid me, I will test that as an inductor. It might not be my problem.
                            • taft1957
                              • Oct 2013
                              • 95
                              Glad I didn't throw it away. That means I am back to square one on this set. If that part isn't bad. Then the new power supply was probably OK. As I said in one of my first post. I replaced the power supply, main board, and FRC board, mistaking it for a eprom board. Since none of those boards made the repair, and I thought I had found a bad transformer on the original board. I sent all those boards back. How much voltage am I looking for to light the led's? When you jump 5 volts to power supply on, and 12 volt to backlight on, if there is nothing wrong with the power supply or the main board, or the led's then the backlight should light, right?
                              • taft1957
                                • Oct 2013
                                • 95
                                The inductor was fine. I found a bad fet and replaced it. I jumped the 5 volts to power on, and the 12 volts to backlight on. All voltages came back steady 5 volts and a steady 12 volts. However, at the led + and led - the voltage seems high and is fluctuating from 172 to 175 on both sides. what regulates that voltage?
                                • dick_barton
                                  • Aug 2015
                                  • 6642
                                  • Wales
                                  Is the backlight working now?
                                  • taft1957
                                    • Oct 2013
                                    • 95
                                    where can I buy a portable led driver to test a led backlight?
                                    • CapLeaker
                                      Leaking Member
                                      • 8153
                                      I power mine on a CV CC variable bench / lab PSU.
                                        We need to see the straight shot pictures of the bottom side of the board to see if it has one or more than one LED driver circuits.
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          09-06-2024, 05:59 AM
                                          HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 02:15 PM
