blaupunkt 32/146L-GB-6B tp.msd309.bp 85 restarting
  • sordids999
    • May 2013
    • 2155
    Hello guys
    got this tv today tv will turn off back lights flash on but then keeps restarting in a loop
    suspected that its a bad led but voltages are stable going to back light around 60 volt but then rises once backlight comes on then decreases and tv then restarts over and over ?
    any ideas guys ?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: blaupunkt 32/146L-GB-6B tp.msd309.bp 85 restarting
    Failed firmware I have a Bush 28" with the same issue failed firmware causing it to be stuck in reboot loop. Absolutely shite Tv's these are.
    • sordids999
      • May 2013
      • 2155
      sorry forgot to add i changed the eeprom but still the same
      • Malachi
        • Dec 2015
        • 1077
        • Usa
        Originally posted by sordids999
        Hello guys
        any ideas guys ?
        A picture from the back showing all the boards and how they are connected will help us help you fix this TV.
        • Diah
          • Feb 2013
          • 6399
          Originally posted by Malachi
          A picture from the back showing all the boards and how they are connected will helps help you fix this TV.
          its early TO March LIE...
          how did you changed eeprom. ? and which bits you wrote on it...
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Wait so you have sound and image on the Lcd ?
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Thats literally it in the Tv lol one big Pcb. Its just shit haha
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Preprogrammed one from OHM supplies.
                • Diah
                  • Feb 2013
                  • 6399
                  i see it seem the photo on first post before replacing eeprom... sorry....
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    No worries lol
                    • sordids999
                      • May 2013
                      • 2155
                      correct
                      and no sound or image backlight lights up for about 2 secs then restarts in a loop
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Hmm doubt the Bl would be causing that though. It should work with the Bl on or not, what happens when you in plug the Bl ?
                        • sordids999
                          • May 2013
                          • 2155
                          if you mean unplug the backlight ?
                          then its still the same i thought that i found a diode that was shorted but once removed from circuit it was fine
                          • Diah
                            • Feb 2013
                            • 6399
                            did you see picture on the screen when you put flash light?
                            • sordids999
                              • May 2013
                              • 2155
                              No i only have literally one second before the backlight goes off
                              • Diah
                                • Feb 2013
                                • 6399
                                you have bad led open and one shorted
                                • sordids999
                                  • May 2013
                                  • 2155
                                  Thanks ill open it up and take a look and hopefully report back
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    Hmm I dont think so but worth a try to check it, also be very careful the Lcds in them are paper thin.
                                    • Diah
                                      • Feb 2013
                                      • 6399
                                      when he remove the first front frame, put LCD on face on clean table then left it fro other, so it will stay as its, same way to to bring it back. place chassis frame on the lcd which grounded on the table
                                        So it keeps restarting, and still doing the same without LED connector (the one with RED/WHITE wires).
                                        Will it also restarting if LVDS cable is also disconnected?
                                        And how do you stop it from restarting? Unplug the AC power cord or you can still use the power switch or the remote to turn it off?
                                        • Takeatry
                                          Yet another Samsung QLED Boot Loop
                                          by Takeatry
                                          Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                          10-04-2024, 02:57 PM
                                        • murko1
                                          HP zbook 17 G3 T7V35ES - endless restarting pre-POST loop
                                          by murko1
                                          Hello community,
                                          I am hoping that you could help me diagnose and find solution for my problem with HP ZBook 17 G3 T7V35ES.
                                          I will try to describe my problem by posting exactly what I asked on official HP support forum, on reddit, etc.. (basically everywhere I posted, but got zero solution/help).
                                          Original post from 14.12.2020 at HP Support Forum : (link here)
                                          Hope you read it all, because I will continue the story - after around 4 months from the time I wrote that original post - the notebook turned on correctly...
                                          05-13-2021, 11:03 AM
                                        • blaster_
                                          Samsung UE49MU6105K - boot loop, horizontal lines
                                          by blaster_
                                          Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
                                          Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
                                          06-22-2022, 05:19 PM
                                        • Stefano Crivellari
                                          Lenovo Legion 5 (15ITH6H) kind of boot loop but not sure
                                          by Stefano Crivellari
                                          Hi, I wonder if anyone can help me fix my Lenovo Legion 5 (15ITH6H) laptop. Basically, after a windows update the computer would not boot anymore. When powering on the laptop the screen has no backlight and nothing would show up, using an external monitor did not help. However, the laptop would still spin up the fans and turn on the keyboard backlight. The keyboard backlight intensity function key would work and the power button led and the charging led are also working. I've tried every possible combination of key press and power button hold down time but did not change anything. At this point...
                                          01-14-2025, 03:49 PM
                                        • ferah831208
                                          HP gaming 15-0013dx quanta G3HA no video, screen polarize on and off loop
                                          by ferah831208
                                          I have an HP gaming 15-0013dx laptop , motherboard quanta G3HA with AMD Ryzen 5 cpu and Nvidia discrete grsphics card. The laptop turns on and u can see the screen polarizing on and off in a loop but no video signal. All voltages are ok measured and stable (I checked all with oscilloscope). This schematics don't have power sequence but I'm using a similar sequence from another laptop with AMD CPU and I get all to the point CPU must release apu_pwrok and apu_rst#, this signal comes valid only for the period of time the screen is polarized and they disappear and same loop behaviour (active/inactive)....
                                          12-07-2024, 04:02 PM
