philips 50pfp5332d/37 keeps blowing fuse
  • newagedevil
    • Mar 2016
    • 6
    • united states
    I have a 50 in philips plasma 50pfp5332d/37 that recently made a click/pop sound and stopped working. It has no power,no led lights nothing. I took the back off and noticed a few capacitors bulging, but the fuse closest to the where the ac comes in on the power boards was blown. I changed it and as soon as I plugged it back into the wall the tv made a click sound and the fuse blew immediately. Put in another fuse and done the same thing. I unhooked all the other boards from the power board and tried it again and the fuse blew again. I have read it could be the bridge rectifier, but I don't know what that looks like or where it would be on the board. I can upload some pics if that would help. Would really like to see what the bridge rectifier looks like for this tv. sorry for my limited knowledge on this, thanks
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: philips 50pfp5332d/37 keeps blowing fuse
    Do you have a DMM and know how to check for S/C ?
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      All the bulging capacitors will require replacing too.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Also we need to know what Pus it needs with images, these Tv's use up to 3 different types of power supplies.
        • flocko
          • Nov 2012
          • 1121
          Most are fitted with the Samsung LJ92-01511A power board
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Most are but there are a couple of others that I have repaired.
            • newagedevil
              • Mar 2016
              • 6
              • united states
              I dont have a dmm at the moment,the board # is lj41-05253a hope these pic loaded right, thanks
              • newagedevil
                • Mar 2016
                • 6
                • united states
                Also the board does have the pba code lj92-01511a
                • sordids999
                  • May 2013
                  • 2161
                  The capacitors that are bulged will need changing have you checked if all fuses are blown ?
                  just a rough idea how to test a bridge rectifier
                  https://www.youtube.com/watch?v=dqkT6hF0O3E
                  hope this helps
                  • newagedevil
                    • Mar 2016
                    • 6
                    • united states
                    The other fuses have been changed also, just don't know what the bridge rectifier looks like on this board or location,can't find any pics of it, thanks for the replies everyone
                    • flocko
                      • Nov 2012
                      • 1121
                      This board has two bridge rectifiers fitted to the left hand heat sink (that them with four legs) just above the fuse that is blowing. when you have a dmm come back we can run though testing with you
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        There is no point in throwing fuses at it, they are blowing for a reason. You need to check the mains AC inout side for shorts then get back to us. Also every cap in the image I screen shotted MUST BE CHANGED as well as the 5V standby cap which I will also screen shot if not psu will fail again.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          5vstby cap needs to be changed after repair too.
                          • flocko
                            • Nov 2012
                            • 1121
                            Strange power board these for a Samsung, with the mains supply only connected the board should show all small voltages and a solid green LED lit on daughter board, that flashes a fault code much like the BN44-00222A when its faulty.the Va + Vs come up when Vs on is made high from 5v
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Yeah they do actually shut down the 5v and 12v rails after 10-20mins I modded fans into the same Tv with this Psu they were on for about that long after I put it into standby and it stopped the Vs rails. But if you press the power off button on the side the 5v goes low and the relay shuts off stopping every voltage rail apart from 5vstby. I do agree it is ood lol
                              • newagedevil
                                • Mar 2016
                                • 6
                                • united states
                                ordered a dmm, should have it wednesday. wondering if a psu from a philips 42pfp5332d/37 plasma would work for the 50in, i may have found a unit i can get fairly cheap thanks again
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  No it wont, 50" uses more power and the 42" is not capable of supplying it and will probably just not even turn on.
                                  • ZnsaneRyder
                                    • Oct 2015
                                    • 88
                                    • Merica
                                    I just repaired one of these exact TV sets.
                                    I had to replace inrush limiting R4006 and R4007 with Large NTC Thermistors because the blowing fuses smoked the originals. The NTC Thermistors are better anyway.
                                    Replace BOTH SAMWHA 450V 270uf with something similar or longer lasting. I had a SHORTED cap in mine causing it to blow fuses, the fuse located between the caps. I used Samsung 220uf 450V.
                                    Replace the G-LUXON 250V 820uf with something longer lasting. The value (uf) doesn't have to match, just put something better in there. I used a Nichicon 250V 470uf.
                                    On both of these replacements, the caps are taller and narrower so they will not be as close to the heatsinks, and makes the caps have longer life.
                                    Now Replace anything SAMXON!
                                    All the little green and black low voltage SAMXON caps near and under the heatsink replace ALL of them with similar or better. Also replace the two black SAMXON caps 680uf, 100V. I used 470uf 100V Nichicon, lower ESR caps, they are slightly taller too.
                                    Once you remove and replace all SAMWHA, G-LUXON and SAMXON caps your set will work, these are known issue parts on most PHILLIPS TV, just search this forum, it's well known.
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      First and last point massive FAIL there by decreasing the capacitance, expect it to FAIL very soon.
                                      • ZnsaneRyder
                                        • Oct 2015
                                        • 88
                                        • Merica
                                        The 450V caps are only off by approximately 50uf, not enough to matter. The newer ones are further from the heatsink (taller and narrower) so they also run cooler than the old ones by not being cooked as badly from the heatsink. The 250V, 470 cap has a longer life, and lower ESR than the original junky 820uf, I measured. I usually don't go down on capacitance, I usually go higher, but certain places it is OK. There are other filter caps on the X and Y boards that filter the ripple from there, it doesn't have to be spot on with microfarads.
                                        Another example is replacing a 1500uf CapXon with a 1000uf Rubycon, and it will be just fine. Another example replacing 680uf SAMXON with 470uf Nichicon or Rubycon is just fine.
                                        The "Rating" of the cap means squat when its a junk brand. A lower rated higher quality cap will hold up fine. Lets not debate, this TV will be just fine.
                                        • Dannyx
                                          UC3842 Power Adapter Blowing Fuse
                                          by Dannyx
                                          Good day folks......wow this new layout is weird. It's like I woke up one day and I'm no longer on Planet Earth or something
                                          Anyway....got this here power brick from a USB to SATA adapter which keeps blowing the fuse after I almost repaired it. The reason I even bother to fix a power brick (wall wart, whatever) in the first place is because this thing was really convenient to use: I'd just plug it and that's it. It's a dual output supply, for both 12v and 5v, which although I COULD easily obtain with a DC-DC converter from a standard 12v adapter, I thought I should crack open the...
                                          12-05-2023, 12:06 PM
                                        • Tips
                                          Samsung PD27AOQ (BN44-00506B) constantly blowing internal fuse.
                                          by Tips
                                          Looking for some assistance please.
                                          Trying to repair a PD27AOQ samsung power board.
                                          Initially had the typical problem of cm806 capacitor blown, additionally thermistor NT801s blown.
                                          Replaced the ceramic capacitor, str60252s, bridge rectifier, thermistor and fuse.
                                          Testing it the fuse blows immediately power is turned on.
                                          diodes dm852 and dm853 test as shorted when in the board but fine when removed.
                                          any assistance, guidance would be appreciated.
                                          04-11-2024, 11:24 AM
                                        • RogerH58
                                          Samsung 46" TV LE46B530 blowing fuse
                                          by RogerH58
                                          I am a newbie and not very experienced so bear with me if i struggle sometimes with technical language - but I'll do my best. I searched "Samsung" and the model number on the forum but didn't find anything I could understand!
                                          I'm not an electronics guy - just picked up stuff over the years through my flight-simming hobby.
                                          I have the above mentioned 46" tv as the monitor for my flight-sim setup. Recently it went "crack" and stopped working. No standdby light and no response. I assumed a fuse had blown and after investigation...
                                          06-10-2023, 10:27 AM
                                        • corrize
                                          A funny fuse story – Lumix LX100 II
                                          by corrize
                                          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                          10-19-2023, 09:58 AM
                                        • trunks81
                                          Philips 47PFL4606 No Power Fuse Keeps Blowing
                                          by trunks81
                                          Hello
                                          Ive got one other 47PFL4606, only this one the fuse keeps blowing !
                                          I allready replaced the next parts
                                          BD901
                                          D901
                                          Q902
                                          Q901...
                                          07-22-2020, 02:25 PM
