Philips 42pfl7603d/10 dead
  • finntricky
    • Jan 2014
    • 449
    • uk
    #41
    Re: Philips 42pfl7603d/10 dead
    Originally posted by Moreno83
    I measure 32V DC on C906 and 10V on C912
    so by your readings, my board readings are wrong,
    i did say they did'nt look right on those caps, so the fault is before the voltage gets there, but where,??????
    and no, never had 3.3v standby to start with, hence this thread.
    thanks to budm, we have got as far as we have, but did'nt think it would take this long to find the problem,
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8327
      Check BD2, D910 and R901 (fusible resistor). Maybe look at the schematic diagram, that Budm provided, everything is in there.
      • finntricky
        • Jan 2014
        • 449
        • uk
        #43
        i have now spent hours looking at the SCH and have tryed to follow it, looks stright forward, and i can see how the parts are conected and why budm has told me what to check, but have still not found the faulty item,
        am i right in thinking if BD2 was at fault, then i would not have 335 volts at C902,
        D910 tests ok, and R901 test ok as before.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8327
          Be careful on the primary side. Put the negative lead on the negative side of c902 and the positive lead of the DMM on pin 5 then pin 6 on that transformer. If you get high DC voltage, the primary side of the STBY circuit is o.k. And th problem is on the other side of the transformer, or the transformer itself.
            OK, IC901 SMPS for the 3.3VSB is ICE3AS02, the start up Voltage at the VCC pin has to reach 15VDC which you are not getting that Voltage for the circuit to startup, so it can be the startup/running cap C912 may be bad, or the internal charge pump inside the IC is bad.
            BTW, R916, R903 are OK?
            • finntricky
              • Jan 2014
              • 449
              • uk
              #46
              Defo not the cap, even took it out again and replaced, also the the R916 R903 check out fine to, so thanks guys for all your help, but i now feel the need to put this to bed, without a found fix, so if anybody has got a power board, they wish to sell me, at a good price, (working of cause), let me know,
              • Moreno83
                • Jun 2014
                • 2008
                • The Netherlands
                #47
                Then that IC is dead. I can send you my powersupply if you pay for the shipping+a beer
                Its definately working but its missing 2 blue ceramic capacitors. Board works so you can use it for parts?
                  The IC is the suspect at this point if the startup cap is not bad due to the fact that the VCC never reached the startup level.
                  • finntricky
                    • Jan 2014
                    • 449
                    • uk
                    #49
                    your a good fella, how much would you like for it ? and do you have paypal ?.
                    PM me Moreno83.
                    • malik4
                      • May 2015
                      • 8
                      • pakistan
                      #50
                      i need service manual
                      philips model 42pfl8803d/30
                      power supply not compaer
                      problem backlight on.......................off.........................on........................off
                      plz help
                      • hispeck
                        • Aug 2015
                        • 258
                        • nigeria
                        #51
                        Hello friends, i have same tv, but my the red light is just blinking continuously. and the stanby 3.3v is not stable
                          Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                          I was working on this CNC machine today found no keyboard functioning no control relay powering on
                          The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                          Found shorted diodes on main controller relays there are 3 of them that...
                          01-07-2023, 05:43 PM
                        • kew1701
                          Philips taw6205 ambilight speaker STM32 mcu dead
                          by kew1701
                          Resolved dead cap which burned mcu(stm32f091rct6) ,between vss and vdd on desoldered mcu is short 5.8oh,is there a way to obtain firmware from it.i have firmware,but i thing this is for wifi/bt board phorus 5 which is on top of amp board(here lies dead mcu)...my stm32 flasher is on the way....
                          04-09-2025, 03:59 AM
                        • CoinCoin88
                          Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                          by CoinCoin88
                          I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                          Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                          09-15-2025, 03:36 AM
                        • jm1234
                          9V relay temperature 40C
                          by jm1234
                          Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                          I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                          05-09-2024, 03:03 AM
                        • edugimeno
                          Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
                          by edugimeno
                          Hi everyone!
                          I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
                          I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
                          This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
                          To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
                          I respected the polarity, positive to cathode of protecting diode
                          So provided all...
                          04-18-2024, 01:15 PM
