Samsung ps43d490 cracked screen
  • maxwell2121
    • Feb 2014
    • 10
    I have a Samsung ps43d490a with a cracked screen. As it is probably useless to repair I thought it would be good to learn on as I used to repair CTV's 15 years ago. The y main board has a S/C RJP63K2 FET. As I have no circuit it is guess work, and I am assuming it supplies HT for screen. Is it possible to repair boards and fire up tv WITHOUT screen connected? If anyone has circuit it would be useful.
    Cheers
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Samsung ps43d490 cracked screen
    These Tv's womt turn on with out the Pdp connected, the controller detects that the boards are not sustaining the panel and shuts down. Also a cracked Pdp can kill the Ymain as the electrodes in the panel short out which can kill the Ymain. So either the Ymain has died or its going into protect mode because of the cracked panel.
    • maxwell2121
      • Feb 2014
      • 10
      Thanks, so basically a useless cause!!
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Yep these are some of the worst Plasma Tv's out there.
        • Chrissygizmo
          by Chrissygizmo
          02-10-2025, 12:33 AM
        • JunkmanJimbo
          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
          by JunkmanJimbo
          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
          No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
          Please help. Thanks in advance!
          08-12-2025, 11:45 AM
        • Kiberge
          Samsung LH82QENELGC/EN Help needed - Static line on screen
          by Kiberge
          HI guys!
          I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
          I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
          the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
          This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
          04-22-2024, 11:28 AM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • valvashon
          Samsung UN60JU6500, stripe on left side of screen
          by valvashon
          Friend sent me this picture of what their 60" Samsung from 2015 is doing. I didn't have any luck getting rid of a vertical stripe in another TV that developed one so I'm not too excited about trying to fix this one. It's mine for the asking; wish it had a dead power supply or bad backlights instead.
          Is this most likely to be a connection at the circuit board or where the ribbon cable hits the screen itself?
          Update: was just informed that this stripe comes and goes and has been doing this for a couple of months.
          Thanks, Val
          Yesterday, 03:01 PM
