Emerson LF501EM5F shuts down right after turning on.
    Re: Emerson LF501EM5F shuts down right after turning on.
    Right no we need find out if those Voltages on those test points are steady first without the boards connected, then check them again with all the board connected to see which Voltage disappears.
    • Malachi
      • Dec 2015
      • 1077
      • Usa
      Originally posted by budm
      OK, so you do have Voltage. Is it steady?
      How about the DCV on jumper J182 (P-ON+21V)
      J183 (AMP+13V)
      J182 I get 22.65vdc
      J183 I get 13.09vdc.
      • Malachi
        • Dec 2015
        • 1077
        • Usa
        Originally posted by Moreno83
        Yes on boards they start with "D" for diode. C for capacitor and R for resistor.
        A diode measuring OL/Beep only ( out of circuit ) is bad.
        Everything is still on the board, nothing out of circuit.
        Also I haven't disconnected any connectors either as I'm doing these measurements.
        Should I disconnect the LEDs and the main board from the psu when checking these voltages?
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          Well , BUDM is your man for LCD tv's.
          I still think it's a mainboard problem. I think some Vestel and LG tv's had the same problem with just showing LG logo on screen. Corrupt software.
            So you indicated that you have all those Voltages with all the connectors in place then we need clarification on what you mean the TV shuts down, the Power LED goes OFF? I do not know if this TV has power LED or not, or the TV is still actually on but the backlights go off.
            • Malachi
              • Dec 2015
              • 1077
              • Usa
              #26
              The power led stays on, red, nothing on the screen.
              If I press the power button, led blinks, Emerson logo comes on followed by the other message, screen goes black and the power led back to solid red.
                Originally posted by Malachi
                Here are the pictures.
                I unplugged the led leads from the psu same cycling. With a flashlight I could see it doing the same thing.
                I disconnected the main board same thing minus the writing on the screen.
                Does that help?
                OK, I am confused! So you indicated shutdown but then in that thread you indicate 'Cycling'.
                When I see the word 'Cycling' I would be looking for Voltage going on and off or cycling up and down but we are not seeing that.
                • Malachi
                  • Dec 2015
                  • 1077
                  • Usa
                  #28
                  Sorry, I gues by cycling I meant that it was doing the same thing when powered on.
                  I realize cycling means continually like I router in a boot loop.
                  Sorry, I'm new at trying to fix tv's.
                    OK, thanks for the clarification. We should check the DCV on the LED connector next.
                    Leave the read probe on one pin at a time then turn on the TV and see what you see on the meter when the backlights come on and when it goes out, then do the same thing on the next pin, and so on.
                    How many wires are there on that LED connector? I see six wires:
                    Red = ??? V (Backlights ON), XXX V(Backlights go OFF)
                    Yellow =
                    Blue =
                    Grey =
                    Black =
                    White =
                    • Malachi
                      • Dec 2015
                      • 1077
                      • Usa
                      #30
                      There are 6 wires in the connector. Top to bottom, red, yellow, blue, grey, black and white.
                        I updated post 29.
                        • Malachi
                          • Dec 2015
                          • 1077
                          • Usa
                          #32
                          Red 60vdc, yellow got as high as 9vdc, blue got to 80vdc, grey drops below 0.86vdc when turned on, black 80vdc and white 0.8.1vdc
                          • Malachi
                            • Dec 2015
                            • 1077
                            • Usa
                            #33
                            How do I measure the web the backlight goes off? The voltage keeps dropping, they start dropping as soon as the back lights go off.
                              That looks bad.
                              Disconnect the LED connector and do the same test again.
                              • Malachi
                                • Dec 2015
                                • 1077
                                • Usa
                                #35
                                Red stayed the same, yellow below 1vdc, blue about 79vdc, grey no change, black about 60vdc and white no change.
                                So about the same.
                                  OK we need to trace out the connection on the Yellow, Grey, and White pins top see if they are LED Cathode return wire of the LED strings or not.
                                  Just to be clear on the Grey wire 'grey drops below 0.86vdc' you said it drops below 0.86VDC but how high did it go up too, that is the important info, same for the White wire.
                                  A quick look at the bottom side of the board, it has 3 Voltage boost converters and 3 PWM Controlled power MOSFET.
                                  Red is the Anode, Yellow is the Cathode return of the first LED string.
                                  Blue is the Anode, Grey is the Cathode return of the second LED string.
                                  Black is the Anode, White is the Cathode return of the third LED string.
                                  • Malachi
                                    • Dec 2015
                                    • 1077
                                    • Usa
                                    #37
                                    Grey and white got as high as those voltages.
                                    Is this looking like a psu problem seeing as how the violates are about the same even with the led disconnected?
                                    Because if you feel it's the psu, I'll just order one.
                                      OK.
                                      Next, can you tell me the Voltage rating as printed on the body of the cap C1305?
                                      • Malachi
                                        • Dec 2015
                                        • 1077
                                        • Usa
                                        #39
                                        It says 100v.
                                        Working psu is right around $50 obo.
                                        $50 on shopjimmy.
                                          Looking at the readings on the Grey and the White wires, I would say you have two LED strings with open circuits.
                                          You can prove that buy removing the Grey and the White female connectors from the socket and see you will see the backlights come on for second or not, that is what I would do.
                                          • JonnyS
                                            PS4 pro PSU ADP-300CR shuts down when turning on 12V
                                            by JonnyS
                                            I would like to ask for your help to troubleshoot a faulty PS4 pro power supply
                                            I have a st_by voltage ane when i try to power on 12v line PSU shuts off
                                            i measure lot of components but i don't fins faulty piece ,
                                            when i try to power on 12v line voltage increasing to ~420v so it looks like PFC was working,
                                            Now i have no idea what i can do more to fix it and i will be very helpfully to help me in this case.
                                            10-10-2022, 10:34 AM
                                          • DXseekerMO
                                            Emerson LF501EM5F, turns on, logo appears, shuts off, the perfect storm?
                                            by DXseekerMO
                                            Earlier this week I got an Emerson LF501EM5F that turns on, the logo comes up, a menu and the channel box come on and it immediately shuts down a split second later.
                                            This was bought new and went in a Laundromat. From there it was on from 7AM to 10PM every day.
                                            So why is this the perfect storm? A month ago I got an Emerson LF501EM4 and an EM4A, both will not turn on. The EM4A was struck by lightning and has a serial of DS1 The EM5F has a serial of DS5. The EM4 has a DS4 serial and the chirping transformer problem with a replaced power supply.
                                            The info...
                                            04-07-2018, 10:54 AM
                                          • JDC
                                            (SOLVED) - Emerson lf501em5f - Turns on, shows logo, then shuts off.
                                            by JDC
                                            Issue: Emerson lf501em5f turns on, shows logo, then briefly shows what input it is on, then goes black.
                                            Solution: Bad LEDs. In my case, there were 2. This repair may not be worth it unless you're doing it for yourself. I'm personally not a fan of Emerson TVs nowadays.
                                            09-17-2018, 09:58 AM
                                          • Norrecito
                                            PS4 pro PSU (ADP-300FR) shuts down when turning on 12V
                                            by Norrecito
                                            Hello all,
                                            I would like to ask for your help to troubleshoot a faulty PS4 pro power supply (ADP-300FR).
                                            A couple of weeks ago, I've picked up a PS4 Pro (CUH-7216B) from one of the local flee markets. According to the seller, it has a "no power" issue and the PSU is most likely faulty. Based on the cracks on the housing, it was probably dropped.
                                            Tried it at home and sure enough, it had a "no power" issue. (Pressing either the power or eject buttons had no effect).
                                            I took out the PSU and opened it. Immediately noticed...
                                            08-20-2022, 10:26 AM
                                          • huzo
                                            HP Omen shuts down when loading OS
                                            by huzo
                                            The model is 15ec-1061nm
                                            Board number is DAG3EDMB8D0​
                                            SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
                                            10-29-2024, 12:05 AM
