(SOLVED) - Emerson lf501em5f - Turns on, shows logo, then shuts off.
  • JDC
    • May 2015
    • 273
    Issue: Emerson lf501em5f turns on, shows logo, then briefly shows what input it is on, then goes black.
    Solution: Bad LEDs. In my case, there were 2. This repair may not be worth it unless you're doing it for yourself. I'm personally not a fan of Emerson TVs nowadays.
  • Skipper14
    • Aug 2019
    • 9
    Re: (SOLVED) - Emerson lf501em5f - Turns on, shows logo, then shuts off.
    Wish I had seen this post before I spent $60 on a main board. Exact same problem with mine. Luckily I had a TV in my boneyard with a cracked screen (main board was bad too). Anybody in need of a main board?
    • taslan
      Surface 7 Pro wont boot, shows Logo and immediately turns off
      by taslan
      as stated in the title, my surface 7 pro wont boot anymore.
      When i press the power button it shows the square windows logo for a second and immediately turtns off again.
      I dont even have a chance to get into bios or boot from usb.
      While trying to find help online it was suggested to look for help/repair here on badcaps and it might be a ME Region corruption in bios.
      I dont know what that is exactly, but i never tinkered with the bios or windows in terms of hacking/patching etc.
      Bought it directly from microsoft and used it now and then and only...
      01-16-2025, 01:25 AM
    • TheQuentincc
      Dell XPS 9300 (LA-H811P) internal display only shows Dell logo then nothing (everything else works)
      by TheQuentincc
      I have a Dell XPS 9300 that's working perfectly fine with an external display plugged, from windows the internal display isn't detected. At boot I can see the Dell logo then when it should display the boot/bios or whatever the screen goes black (no backlight, no image using a flashlight). I tried unplugging everything on the motherboard except the eDP cable but it didn't helped (so it's not the lid sensor). LCDVDD/backlight power are powered down when this happen, PANEL_BKEN_EC and ENVDD_PCH are also down to 0v. It's weird, it almost feels like the motherboard is shutting down the display...
      06-26-2025, 01:44 PM
    • letmealone
      Smart Tech LE-4048SA stuck at SMARTTV logo: problem solved.
      by letmealone
      I had this tv set, stuck at the 'SMARTTV' screen with coloured logo. Impossible to find the original Smart Tech firmware, so i searched in kazmielec.tech some firmware compatible with the tv-set hardware (CV338H-T42 card and Y400HJ6.PE1 screen). The firmware i tried was wrong and it bricked the TV, just showing a black screen and not entering stand by anymore. I supposed it needed special hardware to reflash the NAND, but i was wrong, it just needed a working compatible firmware. Still in the kazmielek page i tried ' CV338H-T42_1920x1080_Telefunken TF-LED43S81T2' and it finally worked. I wrote...
      09-16-2024, 10:03 AM
    • USmechS
      Hisense 65H6570F Logo shows then turns off
      by USmechS
      Hello everybody,
      I had this Hisense TV since November 2019 (Bestbuy Blackfriday special). Couple of nights ago my dad turned it off normally. In the morning it does turn on, shows the Hisense logo, then the LED light flashes and it turns off. It remains in the same state.
      Things I have done:
      A. Plug it off and on.
      B. Plug it off, pushing the power button for up to 2 minutes, plug it in.
      C. Contacted the customer service, They sent me a firmware update, with the file name:
      upgrade_loader_no_tvcertificate.pkg
      The zip file has this...
      04-25-2022, 03:06 PM
    • Verlengsnoer
      Bios splash/logo change
      by Verlengsnoer
      at firs, i hope this is the right place to post my question.
      Im looking for a tool to change the bios logo.
      everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
      i know that HP has a build in option to change the splash logo.
      but i want to change the manufacturer logo to an own logo.
      I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
      10-28-2022, 09:52 AM
