Emerson LF501EM5F shuts down right after turning on.
    Re: Emerson LF501EM5F shuts down right after turning on.
    Right no we need find out if those Voltages on those test points are steady first without the boards connected, then check them again with all the board connected to see which Voltage disappears.
      Originally posted by budm View Post
      OK, so you do have Voltage. Is it steady?
      How about the DCV on jumper J182 (P-ON+21V)
      J183 (AMP+13V)
      J182 I get 22.65vdc
      J183 I get 13.09vdc.
        Originally posted by Moreno83 View Post
        Yes on boards they start with "D" for diode. C for capacitor and R for resistor.
        A diode measuring OL/Beep only ( out of circuit ) is bad.
        Everything is still on the board, nothing out of circuit.
        Also I haven't disconnected any connectors either as I'm doing these measurements.
        Should I disconnect the LEDs and the main board from the psu when checking these voltages?
          Well , BUDM is your man for LCD tv's.
          I still think it's a mainboard problem. I think some Vestel and LG tv's had the same problem with just showing LG logo on screen. Corrupt software.
            So you indicated that you have all those Voltages with all the connectors in place then we need clarification on what you mean the TV shuts down, the Power LED goes OFF? I do not know if this TV has power LED or not, or the TV is still actually on but the backlights go off.
              The power led stays on, red, nothing on the screen.
              If I press the power button, led blinks, Emerson logo comes on followed by the other message, screen goes black and the power led back to solid red.
                Originally posted by Malachi View Post
                Here are the pictures.
                I unplugged the led leads from the psu same cycling. With a flashlight I could see it doing the same thing.
                I disconnected the main board same thing minus the writing on the screen.
                Does that help?
                OK, I am confused! So you indicated shutdown but then in that thread you indicate 'Cycling'.
                When I see the word 'Cycling' I would be looking for Voltage going on and off or cycling up and down but we are not seeing that.
                  Sorry, I gues by cycling I meant that it was doing the same thing when powered on.
                  I realize cycling means continually like I router in a boot loop.
                  Sorry, I'm new at trying to fix tv's.
                    OK, thanks for the clarification. We should check the DCV on the LED connector next.
                    Leave the read probe on one pin at a time then turn on the TV and see what you see on the meter when the backlights come on and when it goes out, then do the same thing on the next pin, and so on.
                    How many wires are there on that LED connector? I see six wires:
                    Red = ??? V (Backlights ON), XXX V(Backlights go OFF)
                    Yellow =
                    Blue =
                    Grey =
                    Black =
                    White =
                      There are 6 wires in the connector. Top to bottom, red, yellow, blue, grey, black and white.
                        I updated post 29.
                          Red 60vdc, yellow got as high as 9vdc, blue got to 80vdc, grey drops below 0.86vdc when turned on, black 80vdc and white 0.8.1vdc
                            How do I measure the web the backlight goes off? The voltage keeps dropping, they start dropping as soon as the back lights go off.
                              That looks bad.
                              Disconnect the LED connector and do the same test again.
                                Red stayed the same, yellow below 1vdc, blue about 79vdc, grey no change, black about 60vdc and white no change.
                                So about the same.
                                  OK we need to trace out the connection on the Yellow, Grey, and White pins top see if they are LED Cathode return wire of the LED strings or not.
                                  Just to be clear on the Grey wire 'grey drops below 0.86vdc' you said it drops below 0.86VDC but how high did it go up too, that is the important info, same for the White wire.
                                  A quick look at the bottom side of the board, it has 3 Voltage boost converters and 3 PWM Controlled power MOSFET.
                                  Red is the Anode, Yellow is the Cathode return of the first LED string.
                                  Blue is the Anode, Grey is the Cathode return of the second LED string.
                                  Black is the Anode, White is the Cathode return of the third LED string.
                                    Grey and white got as high as those voltages.
                                    Is this looking like a psu problem seeing as how the violates are about the same even with the led disconnected?
                                    Because if you feel it's the psu, I'll just order one.
                                      OK.
                                      Next, can you tell me the Voltage rating as printed on the body of the cap C1305?
                                        It says 100v.
                                        Working psu is right around $50 obo.
                                        $50 on shopjimmy.
                                          Looking at the readings on the Grey and the White wires, I would say you have two LED strings with open circuits.
                                          You can prove that buy removing the Grey and the White female connectors from the socket and see you will see the backlights come on for second or not, that is what I would do.
