Lg plasma tv will not power up. 60pc1d
  • clublex
    • Feb 2016
    • 57
    Re: Lg plasma tv will not power up. 60pc1d
    Originally posted by ReeceyBurger123
    Check the Sus output from the Ipms.
    IPMS? im not sure what that is and where the sus output is located? Greenpea!
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Wait hang on have you tried running the test patterns ?
      • clublex
        • Feb 2016
        • 57
        Originally posted by reeceyburger123
        check the sus output from the ipms.
        ipms? Where is the sus output? Rookie here need guidance!
        • clublex
          • Feb 2016
          • 57
          ROOKIE HERE. How do I check the test patterns? Thx so much for your help.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Check on google how to run Lg plasma test patterns. You might need to remove the mobo to do this though as you will need to access the control board.
              When you are reading "1" on the Vs pins, what mode are you using, and what range?
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                #27
                Think it was in diode mode so basically OL. I think.
                • clublex
                  • Feb 2016
                  • 57
                  yea in diode mode. I am using a non audible DVM so 1 I believe is the same as OL.
                  • mmartell
                    • Oct 2013
                    • 3189
                    There must be an ohms mode on your meter. It doesn't have to beep, just write down the readings.
                    • clublex
                      • Feb 2016
                      • 57
                      OK this is what I have for the readings.
                      My DMM IS set on DCV. 200
                      The sticker on the TV shows; VA=60V...... VS =193V
                      there are 3 VS LOCATIONS. I plugged the tv in and it clicked twice on and twice off. I measured the 3 VS locations and they were all over the place.
                      130 down to 88.
                      The stndby locations all measured 4.9.
                      NOTE; If I leave the tv plugged in, it continuously cycles 2 clicks ON, 2 clicks OFF.
                      I unplugged the YSUS and I had 2 clicks and then NOTHING ELSE. I can press the power button and I get 2 clicks and NOTHING ELSE.
                      What NEXT?
                      • clublex
                        • Feb 2016
                        • 57
                        130 down to 88.
                        What NEXT?
                        • clublex
                          • Feb 2016
                          • 57
                          130 down to 88.
                          What NEXT?
                          • Alastair E
                            Chief Womble
                            • Mar 2013
                            • 1963
                            • U.K.
                            #33
                            Repeating the Same Post--Three Times--Isnt going to make replies ANY faster!!
                            Check for faulty IPM's...
                            TELEFIX
                            • Tynan Dill
                              by Tynan Dill
                              Assuming...
                              11-22-2024, 01:46 PM
                            • PantherDave
                              by PantherDave
                              Hi all!
                              05-29-2024, 02:01 PM
                            • GLISIT
                              by GLISIT
                              01-16-2025, 02:29 PM
                            • Cooperr
                              Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
                              by Cooperr
                              I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
                              The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
                              10-21-2025, 01:11 PM
                              03-31-2024, 02:12 PM
