I got this for a deal. It came with vertical white lines across the screen, evenly spaced i would say maybe 1.5 in between them. The lines appear to have orbiting pixels of mainly white but seem to also contain a little occasional confetti of color i think is what I see.
Lg 60pk550 lines, then half screen blackout issue
Re: Lg 60pk550 lines, then half screen blackout issue
So then, i did the usual poking around looking for a short or loose connection. But nothing. Unplugged some xbuffers, cleaned with electrical cleaner, and unplugging just turned off screen in each location. Unplugged the board itself, same thing. Did each ysus and xsus boards, cleaning ribbon contacts. Only thing that happened after all that is a pop and i think burning smell from the left and center xbuffer boards. I didnt install the black metal cover back over them while i ran the tv, and the elec cleaner had ample time (hour, fast evap kind tooo) to evaporate. So now there is black on 75% of left hand of screen with 2 lines about 1a foot apart within the black side. The remaining is the same i started with.Comment
Well--All it needed before was a Control-Board....
But Now--After it let the smoke out--who knows!
Sounds like you killed the COF chips on the pane, by running with no heatsink--and also the possibility of spiking them when disconnecting/reconnecting when there's a possibility of some voltage still present on the Va etc lines to them...
--Need to leave set OFF for a full 10 minutes before re-connecting/disconnecting any Address-Chips of a Plasma set....
The COF chips are part of the panel, therefore if damaged/killed is Unrepairable....
Should NEVER run any set of any type without the heatsinks on the COF Address-Chips--They will self destruct due to overheat in a surprising short time.Last edited by Alastair E; 03-04-2016, 01:59 PM.TELEFIX
PLEASE DO NOT EMAIL ME PRIVATELY FOR REPAIR ADVICE. QUESTIONS BELONG ON THE FORUM!Comment
Should NEVER run any set of any type without the heatsinks on the COF Address-Chips--They will self destruct due to overheat in a surprising short time.Last edited by Redjess; 03-04-2016, 02:40 PM.Comment
That side of the panel shows activity in the form of lit up black and a couple thin lines. Is that indicative is a dead cof chip? Ill post a pic tonight of its current state. Ill be ordering a control logic board if theres signd its not messed up.Comment
Alright, took a pic, but remeber its resting panel side down on a leather black chair and i lifted it up to take a pic, and the red line is in the center if 60in screen. The pop i heard was not loud at all, and i dont think it came from the board that is working. I dont believe i disconnected the x buffer boards with power on either. I had left the tv on for awhile hoping something would warm up and fix itself, but it didnt. I should have come here and asked first (kicks self).Last edited by Redjess; 03-04-2016, 11:59 PM.Comment
Replaced x buffers, no difference from my pic above. Havent received the ysus board yet to try. But since i had already ordered it, gonna try it and see. Allistair e, any comment on whether it looks like the cof chips are now bad or not?Comment
Took off the ysus board, the logic board and the y buffer boards and reconnected it all back, and only got rid of the red line down center. I'm desperate because i need to either fix and put it up or get rid of it. How can i check if the cof chips are toast? I did notice when i banged the panel some type of warning pops up. Cant see it other then the forst work "this".Comment
Ttt, should get the ysus board today in mail, but i feel the COF went on those sides of screen, but dont know to check it. Lossibly nonone here really knows how to check. My stomach turns when i think about it.Comment
Check the Data-Lines to the affected area of screen with Scope. Also check for supplies Va and 5V to the affected areas.
--Thats how you can confirm the COF Chip destruction.
COF chips are VERY EASY to damage. Never ever mess with 'em if there's no need, and there clearly wasn't in your first picture--It was a Control Board issue (Regular lines all over screen).
Y-SUS will Not cure this problem, only Panel Replacement will..TELEFIX
If the cof were destroyed, it was because i had tv on while the black metal "heatsink" was removed. I had no idea what it was. Thats when i heard the popping sound. And allistair, by scope you must mean magnifying glass right?Comment
by Stanley1843Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
by ChrissygizmoHello everyone, I’ve just been given a Samsung UE55JU6800K smart tv as it had white spots on the screen due to the led lenses falling off. After refitting them & putting the tv back together I thought it was a nice easy fix for a free bedroom tv , then I tried it before screwing the back into place. I realised that the right side of the screen was darker than the other side, I removed the screen again as I thought the backlights had failed but they are fine.
I put the screen back in place & turned it back on . The screen seemed to be ok again but different screens on the same... -
by jeyoung12Hi all
I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
So....i don't know what end of the C ribbon to work with... -
by dvu0627I have a Sony Smart TV XBR65X900H that started to have horizontal lines on the right side of the screen (see attached picture). When I played video on Youtube green horizontal line at regular intervals(1/4") across the screen.
I replaced the T-Con board but the lines are still there.
I believe this issue is from the Main Board. Before I replace the Main board, I wanted to seek advise if this is the problem from the Main board or something else?
Thank you for the help.... -
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... - Loading...
