Panasonic dp42d23
  • superbob8
    • Mar 2016
    • 21
    Re: Panasonic dp42d23
    Hi Dick I will do that and get back to you but does anybody know where I can get a schematic for the led dp42d23 tv .It would appear that whatever is supposed to generate 12 vdc to appear at these test points on the power supply is defective .There is 0 voltage
    at these test points so I came come to the conclusion my first issue is in the power supply board .
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Hello superbob8,
      This is not necessarily the case. Any number of non related power supply faults could instruct the mainboard to keep the power supply in standby mode by not issuing a Power On signal. Knowing what the voltages are on the pins tends to guide you to where the fault actually is.
      • superbob8
        • Mar 2016
        • 21
        Originally posted by dick_barton
        Hello superbob8
        In order to help you and without the TV in front of us and having now previous knowledge of the TV you need to provide as much information as possible.
        The connector I highlighted, can you list the names of the pins and what voltages are on each of them in turn. The name of the pins are written above the connector but I cannot make them out from you picture.
        If you have 5v but not 12v then we need to know what voltages are on those pins. Please can you list all the pin names and what voltage you read alongside the name so as to give us a clue if it is a mainboard or power supply fault.
        on every pin that is supposed to have 12 v there is 0 voltage every pin that shows 5 v has 5 volts
        • superbob8
          • Mar 2016
          • 21
          • Chrissygizmo
            Panasonic TX-48CX350B backlights but white screen , blank screen
            by Chrissygizmo
            Hi all, I’ve got a problem I hope someone can help me fixi.
            I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
            01-11-2025, 03:18 PM
          • BigPete
            Panasonic Heatpump Dryer Repair
            by BigPete
            I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
            The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
            In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
            Unfortunately the whole machine has to come apart to fix it.
            I have...
            11-01-2025, 06:40 PM
          • Andre Gilbert
            by Andre Gilbert
            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
            11-20-2024, 08:52 PM
          • hasel17
            CH341a can erase and read but can't write and blank check
            by hasel17
            So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
            Code:
            Checking for blank...
            (Press
            10-26-2023, 06:20 AM
          • AquaMan Ua
            by AquaMan Ua
            05-17-2025, 09:40 AM
