Lg423000
  • corrize
    Nikon D800 camera - flash don’t work and capacitor don’t charge
    by corrize
    Hello, I'm stuck in troubleshooting…
    The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
    In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
    When I press the flash button, it's detected by the system, flash icon appear on LDC display....
    10-01-2022, 10:02 AM
  • kenkaniff
    HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
    by kenkaniff
    Product Name: HP Pro x360 Fortis 11-inch G9
    System BIOS: U94 Ver.01.08.00 10/06/2023
    Serial Number: 5CG31946F5
    SKU Number: 85W05EC#AK8
    Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
    This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
    I needed to remove bios password...
    10-01-2025, 04:32 AM
  • ekozeko333
    by ekozeko333
    🧠 What I’ve Done So Far
    Flashed...
    06-21-2025, 02:48 AM
  • mkdj
    What should I do after having flashed a BIOS?
    by mkdj
    Dear all,
    I did my first laptop repair related to a BIOS issue. Laptop is a Lenovo ThinkPad T480, and was not booting. With my brand new programmer, I did a back-up of the current not working BIOS, erased the BIOS chip, and flashed this dump: https://www.badcaps.net/forum/troubl...83#post3686683
    Now the laptop works fine, I can access BIOS and boot on a USB drive. But I read stuff about DMI, and...
    09-09-2025, 09:45 AM
  • spmetroil
    Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
    by spmetroil
    I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
    The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
    I have a CH341A programmer and I already attempted the following steps:
    1. Identified the correct chip (W25Q128, 3.3V SPI flash).
    2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
    3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
    08-19-2025, 09:23 AM
