What should I do after having flashed a BIOS?
  • mkdj
    • Mar 2025
    • 46
    • France
    Dear all,
    I did my first laptop repair related to a BIOS issue. Laptop is a Lenovo ThinkPad T480, and was not booting. With my brand new programmer, I did a back-up of the current not working BIOS, erased the BIOS chip, and flashed this dump: https://www.badcaps.net/forum/troubl...83#post3686683
    Now the laptop works fine, I can access BIOS and boot on a USB drive. But I read stuff about DMI, and information I should transfer from my old non-working BIOS dump to the new one.
    Question #1 : Can someone tell me what should I do after having flashed a BIOS file like I did? You can also provide me a link to a trusted tutorial.
    Besides, I supposed that, as I have flashed a BIOS file, I have lost some info, for instance related to the serial number of the laptop. But when I check on the BIOS of the newly working BIOS, I do have the correct serial number.
    Question #2 : Can someone explains why I still have the right serial number on the BIOS after having flashed a new file found online, unrelated to my previous BIOS?
    Thank you for reading,
    Regards,
    mkdj
  • m1ch43lzm
    • Mar 2019
    • 907
    • Peru
    Lenovo ThinkPads store the serial number/MTM/model name/BIOS password in the EC (embedded controller), on other brands/models (example: Lenovo Ideapad/Legion/LOQ/Yoga/ThinkBook) that info along the Win license key is stored on the main BIOS, what we do is transfer that data from the corrupt BIOS to the new one
    Maybe the Win license key is in your original (corrupt) BIOS, the new one you flashed doesn't have a Win license key, search with hex editor for 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 1D 00 00 00 (hex)
    As long as you flashed a BIOS with a clean ME region, you should have no issues afterwards
    • mkdj
      • Mar 2025
      • 46
      • France
      Dear m1ch43lzm,
      Thank you very much for your explanation, it does make a lot of sense to me.
      I searched the hex chain you wrote in both my corrupted and new BIOS, and I do see what looks like a Win license key in both files, just after the hex chain. I do have slight differences around the license key, as shown on the pictures below. I am talking about the "I" which is ß in the new BIOS, but most importantly about the 3305156851758 which is 3305162513371 in the new one.
      When transferring the license key to the new BIOS, should I also transfer that data that is slightly different?
ID:	3721822 Click image for larger version
      Regards,
      mkdj
      • m1ch43lzm
        • Mar 2019
        • 907
        • Peru
        I downloaded the BIOS you linked, copy the entire block from 88F110-88F22F from your corrupt BIOS, paste overwrite on the new BIOS (make sure the file size doesn't change), the other bytes may be a checksum or something else
        The 330516... value is displayed in BIOS setup under "Preinstalled OS license"/OA3 key ID or something like that
        On Windows, open command prompt and run the following command:
        Code:
        wmic path softwarelicensingservice get OA3xOriginalProductKey
        It should return the Win key embedded in BIOS, like this:
        Code:
        XXXXX-YYYYY-ZZZZZ-AAAAA-BBBBB
        • Loli Popu
          DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
          by Loli Popu
          Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
          12-13-2024, 03:28 AM
        • drux
          Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
          by drux
          I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
          Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
          These models have AMI/Aptio BIOS.
          Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
          11-03-2024, 01:18 AM
        • zenius
          by zenius
          12-08-2024, 06:13 AM
        • lucaszmn
          by lucaszmn
          Problem:
          Initial Findings:
          • I concluded that the
          08-12-2025, 03:01 PM
        • Bloodhoundje
          by Bloodhoundje
          03-16-2024, 03:12 PM
