sony T-con repair
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    sony T-con repair
    Thought I share this for maybe future sony guy's.
    I have a KDl-52S5100 that would loose picture after 30 seconds,backlight would stay on,sound works,just no picture.
    Measuring around on t-con I found RD69 to be stable 4.5v on chip side,3.2v and dropping on other side.
    Soldered a 15 ohm on top of it and it brought voltage up to 8.2v stable.
    TV been on for 48hrs now.
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    Re: sony T-con repair
    What is the P/N of that IC? It looks like multiple switching power supplies controller.
    Vin is fed into that inductor L3 and that resistor is connect to the output side of the inductor, it looks to be for making VDD_1.
    L4 is for VDD.
    If you can get the spec sheet of the IC then you can tell what the function of that resistor is.
    • martino
      Not so "senior"
      • Aug 2013
      • 997
      • canada
      I've been looking for my magnifying glass without any luck. Wanted to read the numbers on that resistor aswell. I cant read the IC,my eyes are old.
      I was wondering if the value of the resistor is in direct control of the voltage produced.
      15 ohm was a total guess,it gave me the 8.2v I was looking for,lol.
      • tw2005
        • Oct 2011
        • 6458
        ISL97650ARTZ
        Could be 10 or 11 ohm going on the SJ images and versions I see. looks like 100 or 110?. I can make out the ARTZ in your shot.
        Could be pin 3, CB, Logic buck, boost strap pin
          The resistor RD69 (it does look like 110) is between pin 3 (Logic buck, boost strap pin) and pin1/2 (LX1/2 Internal boost connection)? Need verification, same for CD6.
          Per App notes Sch, the CB pin only has cap connected to it.
          What DCV do you at AVDD_I?
          • ivtec
            • Dec 2008
            • 1967
            Hi guys;Ok since the T-con board is the same of my KDL46S4100 i went to check RD69
            and i can reed clearly 110 =11 ohm correct me if i'm wrong.
            Also turned tv on and i only have 0.230v or so both sides.
            here some strange i just went back to the white FP1,and i get 11.6v on one side and on the other side i get about the same as RD69,is this normal?
            • martino
              Not so "senior"
              • Aug 2013
              • 997
              • canada
              you just found the problem with your t con board !
              That fuse blew open,probably due to fatigue.
              Replace that fuse and you should be up and running
              • ivtec
                • Dec 2008
                • 1967
                Thanks maritino i will give it a try,can i use any other fuse or i have to use that specific white one, just to try if it works? thanks
                  You can use 3A fuse with lead wires and solder them to each end of the blown fuse to test.
                    BTW; https://www.badcaps.net/forum/showthread.php?t=52319
                    In my post 5 (Backlights but no image on the screen then you should find out if you do have 12VDC on both ends of the SMD fuse on the T-CON board with ref to chassis GND.) of that thread I asked you to check the DCV at both ends of the fuse and you reported the readings OK. (post 11: Thanks budm; i have 11.60v at fuse FP1,)
                    • ivtec
                      • Dec 2008
                      • 1967
                      Sorry you're right budm, it's a defect i have is lack of concentration, i 'm getting old and confused,.
                      now i have changed the FP1 with same amperage i had in my scrap boards, and put back jimmys A board since with the A board that came with tv i could get sound now but no OSD, now with Jimmys board i have Video, sound and OSD, tv is running fine,but i have this stripe on the screen see pic attach.
                      • snme
                        • Feb 2016
                        • 26
                        • AU
                        Confusion would be diminished if your chassis story was not spread across two threads. Can you resume your opening thread?
                        Have you cleaned the ribbon cables and connectors with IPA?
                        PS: I am now quite confused as to when you did and did not have sound. It would help if you can re-express the above comments in more carefully constructed grammar, preferably in the opening thread, with a view to bring conclusion to this story soon.
                        • ivtec
                          • Dec 2008
                          • 1967
                          Ok i will resume to my thread no big deal.
                          By the way what is IPA?
                          • jetadm123
                            • 2169
                            IPA= Isopropyl alcohol = rubbing alcohol
                            • sanjay_9112
                              • Aug 2015
                              • 4
                              • India
                              I am from Bangalore (INDIA)and new user to Badcaps, so not very much aware how to post here.
                              In have the same Sony T Con board "1st Image as uploaded in thread " in my sony bravia.
                              The problem is it has no video display , but backlit, audio is perfectly fine,
                              I checked the TCon board , supply at Fuse is 12 V at both ends , but there is no supply going to FPC 1,FPC 2 points and gamma IC inputs . Please help, I am new to this forum. Appreciate your prompt response. Thanks
                              • Daren87
                                Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                by Daren87
                                I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                08-13-2023, 03:25 PM
                              • iglitare
                                by iglitare
                                09-04-2025, 07:13 AM
                              • kca
                                by kca
                                Hello all ~
                                08-31-2025, 06:38 AM
                              • rimwall
                                Sony KD-65x7500D - double image - Tcon or Panel?
                                by rimwall
                                This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                11-18-2025, 02:09 AM
                              • thelankanguy
                                Sony KD-55X9000F TCON Issue
                                by thelankanguy
                                The TV shows a black screen with no image.
                                TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                Later both ribbons were disconnected and TCON voltages were tested.
                                12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                There is also a short to ground in this circled inductor.
                                Is this a TCON issue or something else ?...
                                12-13-2024, 12:27 AM
