Frozen screen
  • Grunder
    • Jan 2016
    • 323
    • south africa
    Frozen screen
    Hi, I wonder if anybody could help, I Have a Telefunken Lcd. TLED420FDHD (model misleading- not Led lamps inside) Comes on with blue screen & "freezes" just after switch on,& then there are no controls, & no picture. So if you press vol+ at switch on you'll get the vol osd on the screen until you power down & up again. The set looks very basic inside compared to other brand names that i've worked on.
    I've mailed the agent (Nuworld) for price and availability of the main board, which i feel is faulty. My problem is the customer wants a damage report, and the insurance companies always ask if the damage was externally inflicted or due to ware and tare?
  • sordids999
    • May 2013
    • 2160
    Re: Frozen screen
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • Grunder
      • Jan 2016
      • 323
      • south africa
      Re: Frozen screen
      Hi, new to forums, so my navigation a bit dicey. (hope this is going follow my last post?). Sorids999, thanks the response. should have included photos, in the mean time agent has quoted me 20.46 British pounds for the main board, with a 4.55 pound courier fee. (just used converter to convert ZAR to Pounds?)
      I still have to quote my customer, but am now worried it may not be the main board that is faulty? Maybe a shift register on those narrow pcbs above the panel aren't getting clocked?. (maybe i need to read all the tutorials you guys have first)
      • Grunder
        • Jan 2016
        • 323
        • south africa
        Re: Frozen screen
        Sorry. sordids999
        • Grunder
          • Jan 2016
          • 323
          • south africa
          Re: Frozen screen
          How do I attach photos to my posts?
          • CapLeaker
            Leaking Member
            • 8326
            Re: Frozen screen
            click on post reply, scroll down, manage attachments.
            • Grunder
              • Jan 2016
              • 323
              • south africa
              Re: Frozen screen
              Thanks, will try later...
              • Grunder
                • Jan 2016
                • 323
                • south africa
                Re: Frozen screen
                Hi, a photo of the main board that i suspect causing the frozen screen on my Telefunken TLED420FDHD. hope this helps?
                  • 31190
                  Re: Frozen screen
                  can you show the psu board please.
                  • CapLeaker
                    Leaking Member
                    • 8326
                    Re: Frozen screen
                    Found the datasheet to the CV181H-X main board... if it helps any...
                    • Grunder
                      • Jan 2016
                      • 323
                      • south africa
                      Re: Frozen screen
                      Hi, photos, really looks cheap Hey?
                      • Grunder
                        • Jan 2016
                        • 323
                        • south africa
                        Re: Frozen screen
                        Thanks Capleaker for input
                        • Grunder
                          • Jan 2016
                          • 323
                          • south africa
                          Re: Frozen screen
                          Thanks all, the urgency of the customer forces me to return this item unrepaired, and uneconomical to repair. The final diagnosis being a faulty panel. Unfair as it may seem, time has been the deciding factor. Will follow to see if anything else emerges, (and close post?)
                          • Ryan.man
                            by Ryan.man
                            02-04-2025, 12:23 PM
                          • reformatt
                            by reformatt
                            07-31-2025, 08:37 PM
                          • smic717394
                            by smic717394
                            07-25-2024, 10:16 AM
                          • Chrissygizmo
                            by Chrissygizmo
                            02-10-2025, 12:33 AM
                          • ipatch
                            ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
                            by ipatch
                            i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
                            08-24-2024, 02:36 PM
