Proscan PLED5529A Troubleshooting
  • mmartell
    • Oct 2013
    • 3189
    Re: Proscan PLED5529A Troubleshooting
    I've repaired the same fault on an LG plasma. See here
    https://www.badcaps.net/forum/showthread.php?t=50315
    • dspiffy
      • Feb 2016
      • 19
      What does it solder to inside the shielded box? There was what appeared to be a thin, flat wire that broke off.
      • CapLeaker
        Leaking Member
        • 8213
        maybe we can tell if we see the inside that shielded box.
        • dspiffy
          • Feb 2016
          • 19
          I'm reluctant to start unsoldering stuff from the main board until I have a better idea.
            The thin flat wire is the terminal that is connected to the center pin of Ant connector.
            The tuner module has metal shield where the Ant connector is attached to it and the center pin of the connector is soldered to the PCB.
            • mmartell
              • Oct 2013
              • 3189
              Mine was done in situ through the hole with a pencil iron and a little flux. No need for removal.
              • dspiffy
                • Feb 2016
                • 19
                I cant seem to access where the thin flat wire connected without removing the metal shield. I certainly cant see it through the hole.
                • mmartell
                  • Oct 2013
                  • 3189
                  To be fair mine was a solder pad and not aflat wire so iI'm not sure you'd be able to properly anchor it anyway.
                  • howardc64
                    by howardc64
                    07-24-2025, 05:17 PM
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                  • Hakuu
                    by Hakuu
                    Hi There,
                    More Details
                    TV Model - LG OLED77G1PUA
                    07-12-2023, 02:37 PM
                  • jb_Bak
                    by jb_Bak
                    CN6401
                    Pin 01 NC
                    Pin 02 NC
                    Pin 03 "BL_ON": 0V
                    Pin 04 "N/C"
                    Pin 05 "STBY 3.3V": 3.5V
                    Pin 06 "GND": N/C
                    Pin 07 "AC_OFF"...
                    09-27-2021, 04:52 PM
