My new dim bulb tester
  • tech2014
    • Aug 2014
    • 807
    I found a SPST dim bulb tester on a website. It looks much better then the first one I built. Now I can test older equipment without worrying about frying anything at power up. How many of you use this type of tester?
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: My new dim bulb tester
    I do sort of.... Mine has sockets for plugs instead of light bulbs.... It also has a ballast bypass and ground lift switch. Its also rated for 20 amps...... It's not always used to protect the load, but to protect the wiring in the walls when the load burns up
    Follow the white rabbit.
      https://www.badcaps.net/forum/showpo...&postcount=112
      http://www.ebay.com/itm/like/3018206...chn=ps&lpid=82, third one from the left from Home depot, it has lamp socket and switch.
      I use it with my isolation transformer, GFCI, when I do any repair works.
      • tech2014
        • Aug 2014
        • 807
        I need an isolation transformer. Any places that sell these or what parts do I need to build one. Also, I can add a variac to slowly increase AC to see any current meter reactions.
        • tibimakai
          • Jan 2012
          • 3680
          I have one too, thanks to Bud. I have a transformer, which still needs some repair. It was dropped and some stuff got broken in it(the rotor part, which I had to machine a new one). Still needs new brushes.
          • CapLeaker
            Leaking Member
            • 8195
            Here is my dim bulb tester and my isolation transformer.
            • repair-it
              TOSHIBA DLP 52HM95 How to reset timer module on bulb
              by repair-it
              I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
              Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
              10-11-2023, 07:18 PM
            • ezenia
              LUMIMAN Smart Bulb IC ID?
              by ezenia
              I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
              In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
              04-28-2025, 05:56 PM
            • JimBanville
              Replacing incandescent bulb on Pioneer LD player with led. Need help :)
              by JimBanville
              I have a pioneer dvl-909 LD/dvd player from 1998. It has a light on the front panel that lights up when you play a dvd. I removed the bulb and it appears to be a tiny incandescent bulb. Its measures "open"/dead and the bulb is black like it's blown. The socket it fits into measures 5v. I've looked up the schematics and there's no indication of the amperage. I don't want to spend any money on new parts, but I have a pack of like 100, 3v, 20ma LEDs and I have various resistors.
              Is there a way for me to determine the amperage going to the old dead bulb with my multimeter?
              01-24-2023, 07:49 AM
            • Lifeisfun
              Trying to troubleshoot DDR4 SODIMM slot with slot tester
              by Lifeisfun
              Hi folks!
              I have some kind of memory problem on Lenovo laptop. I was initially able to install windows after several tries since the laptop did freeze in middle of those attempts.
              Eventually I discovered that it was related to moving the laptop.
              Later on it even stopped booting unless I pressed around the memory slot. (no keyboard LEDs only power button responds)
              If I remove the RAM I get the beeps that RAM is missing. Inserting the RAM there is silence and it will not boot most of the time. No picture.
              I removed the board got one of those memory slot testers...
              06-04-2025, 02:26 PM
            • spleenharvester
              Reverse engineering of 18650 4-channel tester
              by spleenharvester
              Hi friends
              I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
              05-04-2025, 02:43 AM
