Vizio VW32L HDTV40A
  • Gootch46
    • Oct 2015
    • 57
    Vizio VW32L HDTV40A
    Just picked this tv up I pluig it in, turn it on and it comes on locked on a initial setup wizard screen and it does nothing, I have tried several remotes with it even programmable ones and nothing (TV did Not come with remote)
    So I cvan shut tv off with button, then when I turn it on if I hold the menu button down the tv turns on normal. I can auto search channels and tv will run normal until I shut it off then turn it back on without holding menu button again and it will be locked in that initial screen again. weird anyone seen this before or know what couls cause it? thought maybe a ir board but havent tested anythin g inside the bacvk yet, just wondering if people have seen this .
    Oh by the way i had it running normal for like 3 hours then turned off then on back to setup wizard screen again. Thanks
  • Gootch46
    • Oct 2015
    • 57
    Re: Vizio VW32L HDTV40A
    Nothing? Noones seen this?
      https://cdn.badcaps-static.com/pdfs/...93ef5cdc5c.pdf
      Page 27
      It seems to me that you will need the original remote to do the initial setup the first time, then it will not need to be done again.
      • CapLeaker
        Leaking Member
        • 8223
        Try a new Eeprom? Or heating (hair dryer), cooling (can of air upside down) the main board?
        • Gootch46
          • Oct 2015
          • 57
          Thank you Budm was having trouble finding anything on this and looking to vizio's website wouldve been the last place I thought to look LOL rthought it was just a glitch or a bad ir board, Thanks again
          • CapLeaker
            Leaking Member
            • 8223
            you said several remotes? do you have a original remote?
            • Gootch46
              • Oct 2015
              • 57
              Not "The original " it came with No remote or stand, but I had a vizio here same tv , but it did not work with the tv and I also tried a couple programmable remotes but nada. So might open up to check the ir board , maybe even open up my working tv and swap ir out and see if that does it. Thanks
              • ivtec
                • Dec 2008
                • 1967
                I have a 42"" same model and it came up with a blue screen and sometimes it worked and acted krazy and most times it would not respond to the buttons on the tv controls,on mine it was the 2 Caps on the invert-er board,i got new caps and tv has been working for a year now.
                i have all the boards for the VW32 L in my scrap,don't what board is good or bad cause i can't use them in my VW 42L ,if you were nearby Fall River Mass i would gladly let you try them
                • figurehead21
                  • Jul 2016
                  • 6
                  buttons are bad
                  • mrtek
                    Vizio M65-C1
                    by mrtek
                    Hi.
                    picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                    When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                    This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                    07-14-2025, 07:28 PM
                  • howardc64
                    Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                    by howardc64
                    Failure Symptom
                    No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                    Where is the short?
                    Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                    Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                    05-27-2025, 02:56 PM
                  • howardc64
                    Vizio SmartCast TV software bug that looks like hardware
                    by howardc64
                    Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                    It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                    11-16-2024, 05:17 PM
                  • Novabeau 2
                    Vizio e55u-d2 55 inch tv service manual & schematic
                    by Novabeau 2
                    Hello everyone, I'm trying to find some service manuals or schematics for a vizio e55u-d2 55 inch tv that just conked out the other night. It has no power whatsoever.
                    Have tried all the reset process that vizio had.
                    Any Insight to this would be great and appreciated. If you all think it's not cost prohibited to fix let me know. known thank you and have a wonderful day.
                    04-21-2025, 05:50 PM
