Sony KDL-46S4100 no pic or sound help.
Re: Sony KDL-46S4100 no pic or sound help.
Hi guy; Update on KDL46S4100, i got the new T-con Board and installed same stripe on the screen,don't you think i'm screwed Panel is bad?now i have all good boards parts for this model and no screen panel?, what a bad luck,please say something,at least a word of comfort thanks for you help and patience, at least it's no all loss,i keep learning more and more everyday, with Badcaps forum,the best there is,i learn alot.thanksAttached Filesif you find these attachements useful please consider making a small donation to the site
Panel problem, you can try pressing on the tab bonding or try flexing the panel to see if the condition will change.Never stop learning
Thanks budm; i open it up to get to the those ribbon flexing cables, press them and nothing.there components on the drivers boards?Last edited by ivtec; 03-03-2016, 11:38 AM.Comment
So you open up the LCD panel to get to the Tab bonding then? Unless those driver IC in that section of the screen is bad.Never stop learning
Thanks budm;when i take off the medal frame i get a diferent stripe line see first pic,on the panel flex boards i only see Resistors and caps,see pics.
all the flex tapes seem not to be bad like cut traces like i see on some Utube videos everything seems to fine at naked eye!
Budm do you know what other LCD tv might have this LCD panel?
i was thinking if i could get an used cheap 46 LCD tv that the panel fit in this Sony , i could make an offer,i think Samsung old lcd tvs use to have same Screen panels,
i have taken this #'s,i don't know if there are the panel #'s, can you advise on that.thanks
460H0BSRZLV1.1
K2187E880Zy3
046473Attached Filesif you find these attachements useful please consider making a small donation to the site
It seems to me that since the Vertical lines have changed, I would suspect bad bonding of that brown flexible PCB which is attached to the rigid green PCB, that is where you applied pressure on that section to see if the vertical lines changed from more line to less lines or lines are gone when pressure is applied.
Example of vertical lines due to bad tab bonding.
https://www.badcaps.net/forum/showth...LN52A530P1FXZAAttached Filesif you find these attachements useful please consider making a small donation to the site
Hi, yes i press those bonding tapes and no change,It seems to me that since the Vertical lines have changed, I would suspect bad bonding of that brown flexible PCB which is attached to the rigid green PCB, that is where you applied pressure on that section to see if the vertical lines changed from more line to less lines or lines are gone when pressure is applied.
that 52 " sumsung has exact same metal frame as mine, i wonder if a
LN46A530P1FXZA would fit in KDL 46S4100 ?Comment
That panel model number does not look right,
it should be something like LTYxxxxxxxx or LTZxxxxxx.
LTY460HB10, LTZ460HB10?Never stop learning
where can i find the right # for kdl46s4100
i know nobody sell panels but if i could find another modle that carries same panel,Comment
Pictures of the whole back side of the TV?Never stop learning
thanksbudm; is this what you want, not very good pics, i'l try on day light,cause i have tv in the cellar has poor light. ?,camera is not very good.
Here's a link with better pics;
http://www.justanswer.com/tv-repair/...d-46s4100.htmlAttached Filesif you find these attachements useful please consider making a small donation to the site
I think the LCD panel number sticker is under the metal plate that the main board is attached to.Never stop learning
See page 103:
https://www.badcaps.net/forum/showth...439#post636439Never stop learning
Thanks bunm; i found this too
https://www.encompassparts.com/item/..._46_Lty460hb08Comment
Also Who would dare to pay 1.200.00, unless one is out of his mind ,you can get a modern tv for 350 bucks newComment
Also found out compatible LCD Panel with
46" CLASS BRAVIA SL SERIES LCD TV (45.5" DIAGONALL
Sony KDL46V4100 BRAVIA V SERIES LCD TELEVISION
Sony KDL46S4100 BRAVIA S SERIES LCD TELEVISION
Sony KDL46SL140Comment
Hi guys; Update on Sony Stripes on the LCD screen,i don't think this will make any difference but i'd like you opinion.
As i said with the frame on the stripe is larger , when i take off frame it gets thinner, but i learned in order for the stripe to get thinner i have to take off the frame and reboot TV or turn off and on TV,if i take frame off with TV on there is no effect on the larger stripe,
i'd like to here your take on this.
Also i measure all the caps and resistors on the the Panel assembly board,and on most of the R or caps i measure 3.3v, 7v,15v, or so on one side and the other side i get on most SMT components about 0.350 or so,.Attached Filesif you find these attachements useful please consider making a small donation to the site
by alegatorulsony bravia kdl-43w756c, no power, no sound
the charger brick has 19,2-19,3 vcc
changed the inverter board same result.
where should i start?
cheers -
by iglitareHi,
Or is it always a bad/shorted... -
by AkuankaHi everyone,
I'm troubleshooting a power supply issue with a Sony SLV-E780 VCR. The device clicks repeatedly but doesn't power up completely. I've already replaced five capacitors, but the problem persists.
Here's a video link https://photos.app.goo.gl/3Xki6yvCLn67gLX78 showcasing the sound. Based on your experience, could this be due to a transformer, diode, or another component? Any guidance on what to test or replace next would be greatly appreciated.
Thanks in advance for your help! -
by x_orange90_xFinally got my KD-50X690E up and running after replacing the power supply. Upon testing it I noticed the lack of sound from the speakers. At first I just ignored it thinking it was set to external speakers or some other kind of audio setting. However, after actually going into settings and looking around I see nothing of this sort. I looked it up on Google and apparently a lot of people have disappearing audio on a variety of Sony TVs 🙄. I'm going to see if a firmware or software update will resolve it, if available.
Has anyone else had this happen to their tv?
10-05-2024, 05:01 AM -
by domixHello,
at tv KD - 65XF9005 i have a problem.
Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
is this a common problem for this tv?
i attached pictures of inside. Supply board looks okey, no blowed caps.... - Loading...
