Re: Vizio E470Vl no backlight problem
Show us the pictures of your power supply board and a closed up of the connector on the power supply board that goes to the main board.
Are you having BL-ON control signal from main board problem?
What is the TV not doing?
Which one goes to main to activate BL/ON?Leave a comment:
It was indeed too low of a voltage to activate the backlights. I had the member just jump the PS-ON to the BL-ON pin and snip the wire going to the main board that activates BL-ON. For now, he's watching the TV again with no money spent.Leave a comment:
I know this is an old thread but I'm trying to help out an eBay member with a no backlight issue on this same model. His BL-ON signal is 1.32V and I'm wondering is that's the issue. What is typically enough to activate the backlights? I would think it should be more in the 2.5V - 3V range so I'm thinking he's got a main board problem.
Any opinions are greatly appreciated.Leave a comment:
so uhh.. what ever happened here?Leave a comment:
That is the dual MOSFET:
https://cdn.badcaps-static.com/pdfs/...e9f2435410.pdfAttached FilesLeave a comment:
yep the top line reads 4953gm.the bottom line reads a07014-thanks again for your help. i will post results when i get the part replaced..Leave a comment:
I am curious as to what the U33 is, can you read any printing top the of the body?Leave a comment:
thanks bud-you're the best-got the parts ordered and my fingers crossed-sorry i'm such a newbieLeave a comment:
Vizio 3647-0292-0150 is your main board based on the number as printed on barcode.
http://www.shopjimmy.com/vizio-3647-...or-e470vl.htm#
http://www.shopjimmy.com/vizio-3647-...repair-kit.htm
Per description from SJ:
The Vizio 3647-0292-0150 Main Board Component Repair Kit includes all necessary components to repair common failures on the Main Board. Symptoms include stuck or frozen at the Vizio welcome screen, TV turns on when you press the power button but has no backlights.
Part 2
Symptoms:
No Backlights
Description Quantity Board Location
Integrated Circuits 1 U33
You may want to look at U33 to get the P/N as printed on top of the IC to see what it is what its function is.
Pictures provided by shopjimmy.Last edited by budm; 02-18-2016, 05:08 PM.Leave a comment:
WTF! Really? Lest see now I do not have the exact same board in front of me to trace, that is right, I have done many tracing and reverse engineering many time before for lots of people here for FREE by spending many hours of my own times!
So good luck with your repair if you do not want to do some work.Leave a comment:
So good luck with your repair if you do not want to do some work.Last edited by budm; 02-17-2016, 10:22 PM.Leave a comment:
does anyone know where to buy the 1117 voltage regulators for this tv,thanksLeave a comment:
Unless you have the diagram of the main board, then yes, it is VERY time consuming.Leave a comment:
well i was hoping someone would give me an idea what to check without spending hours looking at traces.i have voltage throughout the board but it just isn't enough to kick on the backlightsLeave a comment:
you need to trace out the back-light signal path using a multi-meter in the continuity function. I had this problem before and I remember some caps and resistors make up the circuit and then to the main processor.
if those caps and resistor are good then its the processor failing to send the voltage to turn on the lamps
you will need magnifying glass 10x or betterLast edited by ecking767; 02-15-2016, 09:43 AM.Leave a comment:
by Bugman1400EDITED: I thought my Vizio E470VL has +5VSB and no 12v on the PS board, but after plugging the cable back in and testing the pins on the Main board I realized that I do have 12V. I assume the 12V is turned on when the ON/OFF switch is pressed. The Vizio light in front does go from Standby Orange to White when ON. But, I still have no picture or sound. Test values of PS board are below.
+5VSB= +5.09
12V= +12.18
PS_ON= +2.25
I_ON/OFF= +3.27
LAMP= +3.18
DIM= +2.97
Any more testing I can do on Main board or is it just a replacement?... -
Assuming...7 Photos -
by mrtekHi.
picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED... -
by dholleyWould someone please help troubleshoot a Vizio 47" TV Switch Mode Power Supply with 5 volt output fluctuating voltage. The voltage fluctuates at 5 the volt output and at the Pulse Switch Modulating IC at VCC. I have the following notes:
1. The 3 main filter caps all have approximately 167 volts steady
2. I have replaced 4 mosfets next to what I think is called the inventor transformer (big black transformer) pictures attached
3. I have replaced Fuse F102 with an equivalent
4. I have check all diodes and caps and they seem to be ok
5. I replaced the 431... -
by howardc64Failure Symptom
No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
Where is the short?
Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but... - Loading...
