Vizio E470Vl no backlight problem
Re: Vizio E470Vl no backlight problem
Vizio 3647-0292-0150 is your main board based on the number as printed on barcode.
http://www.shopjimmy.com/vizio-3647-...or-e470vl.htm#
http://www.shopjimmy.com/vizio-3647-...repair-kit.htm
Per description from SJ:
The Vizio 3647-0292-0150 Main Board Component Repair Kit includes all necessary components to repair common failures on the Main Board. Symptoms include stuck or frozen at the Vizio welcome screen, TV turns on when you press the power button but has no backlights.
Part 2
Symptoms:
No Backlights
Description Quantity Board Location
Integrated Circuits 1 U33
You may want to look at U33 to get the P/N as printed on top of the IC to see what it is what its function is.
Pictures provided by shopjimmy.Last edited by budm; 02-18-2016, 05:08 PM.Never stop learning
I am curious as to what the U33 is, can you read any printing top the of the body?Never stop learning
That is the dual MOSFET:
https://cdn.badcaps-static.com/pdfs/...e9f2435410.pdfAttached FilesNever stop learning
so uhh.. what ever happened here?Don't fear the repair...Comment
I know this is an old thread but I'm trying to help out an eBay member with a no backlight issue on this same model. His BL-ON signal is 1.32V and I'm wondering is that's the issue. What is typically enough to activate the backlights? I would think it should be more in the 2.5V - 3V range so I'm thinking he's got a main board problem.
Any opinions are greatly appreciated.Comment
It was indeed too low of a voltage to activate the backlights. I had the member just jump the PS-ON to the BL-ON pin and snip the wire going to the main board that activates BL-ON. For now, he's watching the TV again with no money spent.Comment
Which one goes to main to activate BL/ON?Comment
Show us the pictures of your power supply board and a closed up of the connector on the power supply board that goes to the main board.
Are you having BL-ON control signal from main board problem?
What is the TV not doing?Never stop learning
by Bugman1400EDITED: I thought my Vizio E470VL has +5VSB and no 12v on the PS board, but after plugging the cable back in and testing the pins on the Main board I realized that I do have 12V. I assume the 12V is turned on when the ON/OFF switch is pressed. The Vizio light in front does go from Standby Orange to White when ON. But, I still have no picture or sound. Test values of PS board are below.
+5VSB= +5.09
12V= +12.18
PS_ON= +2.25
I_ON/OFF= +3.27
LAMP= +3.18
DIM= +2.97
Any more testing I can do on Main board or is it just a replacement?... -
Assuming...7 Photos -
by dholleyWould someone please help troubleshoot a Vizio 47" TV Switch Mode Power Supply with 5 volt output fluctuating voltage. The voltage fluctuates at 5 the volt output and at the Pulse Switch Modulating IC at VCC. I have the following notes:
1. The 3 main filter caps all have approximately 167 volts steady
2. I have replaced 4 mosfets next to what I think is called the inventor transformer (big black transformer) pictures attached
3. I have replaced Fuse F102 with an equivalent
4. I have check all diodes and caps and they seem to be ok
5. I replaced the 431... -
by howardc64Failure Symptom
No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
Where is the short?
Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but... -
by прямоSo I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...3 Photos - Loading...
