Vizio E470Vl no backlight problem
  • chandonh
    • Feb 2016
    • 17
    Re: Vizio E470Vl no backlight problem
    Originally posted by budm
    WTF! Really? Lest see now I do not have the exact same board in front of me to trace, that is right, I have done many tracing and reverse engineering many time before for lots of people here for FREE by spending many hours of my own times!
    So good luck with your repair if you do not want to do some work.
    wow i was just asking if anyone knew where to start like what components to check first.sorry i blew up at ya i guess
      Vizio 3647-0292-0150 is your main board based on the number as printed on barcode.
      http://www.shopjimmy.com/vizio-3647-...or-e470vl.htm#
      http://www.shopjimmy.com/vizio-3647-...repair-kit.htm
      Per description from SJ:
      The Vizio 3647-0292-0150 Main Board Component Repair Kit includes all necessary components to repair common failures on the Main Board. Symptoms include stuck or frozen at the Vizio welcome screen, TV turns on when you press the power button but has no backlights.
      Part 2
      Symptoms:
      No Backlights
      Description Quantity Board Location
      Integrated Circuits 1 U33
      You may want to look at U33 to get the P/N as printed on top of the IC to see what it is what its function is.
      Pictures provided by shopjimmy.
      • chandonh
        • Feb 2016
        • 17
        thanks bud-you're the best-got the parts ordered and my fingers crossed-sorry i'm such a newbie
          I am curious as to what the U33 is, can you read any printing top the of the body?
          • chandonh
            • Feb 2016
            • 17
            yep the top line reads 4953gm.the bottom line reads a07014-thanks again for your help. i will post results when i get the part replaced..
              That is the dual MOSFET:
              https://cdn.badcaps-static.com/pdfs/...e9f2435410.pdf
              • triplefour
                • May 2014
                • 1747
                so uhh.. what ever happened here?
                Don't fear the repair...
                • aaronwt6
                  • Apr 2013
                  • 855
                  • US
                  #28
                  I know this is an old thread but I'm trying to help out an eBay member with a no backlight issue on this same model. His BL-ON signal is 1.32V and I'm wondering is that's the issue. What is typically enough to activate the backlights? I would think it should be more in the 2.5V - 3V range so I'm thinking he's got a main board problem.
                  Any opinions are greatly appreciated.
                  • aaronwt6
                    • Apr 2013
                    • 855
                    • US
                    #29
                    It was indeed too low of a voltage to activate the backlights. I had the member just jump the PS-ON to the BL-ON pin and snip the wire going to the main board that activates BL-ON. For now, he's watching the TV again with no money spent.
                    • Wirenut420
                      • Jul 2020
                      • 4
                      Which one goes to main to activate BL/ON?
                        Show us the pictures of your power supply board and a closed up of the connector on the power supply board that goes to the main board.
                        Are you having BL-ON control signal from main board problem?
                        What is the TV not doing?
                        • Bugman1400
                          Vizio E470VL got +5VSB, but no 12V
                          by Bugman1400
                          EDITED: I thought my Vizio E470VL has +5VSB and no 12v on the PS board, but after plugging the cable back in and testing the pins on the Main board I realized that I do have 12V. I assume the 12V is turned on when the ON/OFF switch is pressed. The Vizio light in front does go from Standby Orange to White when ON. But, I still have no picture or sound. Test values of PS board are below.
                          +5VSB= +5.09
                          12V= +12.18
                          PS_ON= +2.25
                          I_ON/OFF= +3.27
                          LAMP= +3.18
                          DIM= +2.97
                          Any more testing I can do on Main board or is it just a replacement?...
                          09-04-2022, 09:19 AM
                        • mrtek
                          Vizio M65-C1
                          by mrtek
                          Hi.
                          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                          07-14-2025, 07:28 PM
                        • dholley
                          Vizio TV E470VL SMPS Flucuation Output Voltage
                          by dholley
                          Would someone please help troubleshoot a Vizio 47" TV Switch Mode Power Supply with 5 volt output fluctuating voltage. The voltage fluctuates at 5 the volt output and at the Pulse Switch Modulating IC at VCC. I have the following notes:
                          1. The 3 main filter caps all have approximately 167 volts steady
                          2. I have replaced 4 mosfets next to what I think is called the inventor transformer (big black transformer) pictures attached
                          3. I have replaced Fuse F102 with an equivalent
                          4. I have check all diodes and caps and they seem to be ok
                          5. I replaced the 431...
                          01-20-2022, 03:12 PM
                        • howardc64
                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                          by howardc64
                          Failure Symptom
                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                          Where is the short?
                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                          05-27-2025, 02:56 PM
