Philips 55PFL5705D/F7 bad LCD?
  • TeeEeeKay
    • Sep 2015
    • 10
    I have a Philips LCD TV that has the symptoms pictured below. I opened up the set and reseated connectors, which didn't change the symptom. No parts have been replaced. I'm fairly certain it is a bad LCD, but I wanted to pass it by others to get their opinions.
    The pics are showing the set displaying an OTA channel with normal sound.
  • Pragmatiko
    • Jul 2013
    • 468
    • IT
    Re: Philips 55PFL5705D/F7 bad LCD?
    Seem lcd problem
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Yep my bet is failed Lcd
      • alro7779
        Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
        by alro7779
        Hello, guys!
        The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
        09-14-2025, 12:25 AM
      • G33RT
        Philips 8200 series 65PUS8204/12 stuck at Philips Logo
        by G33RT
        Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
        It does power up when pressing the power button.
        I already try the power button while plugin the plug with no result.
        Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
        Could this be an PSU or eMMC issue ?
        07-19-2025, 03:43 AM
      • double_DD
        Philips curling iron - is this a common AC cable?
        by double_DD
        Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
        As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
        Not sure if this is something Philips proprietary, or a standard, but the cable plug...
        08-18-2025, 10:04 AM
      • janos6662000
        Philips 47PFS7509/12 LCD TV problem
        by janos6662000
        Hi
        I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
        When i applied cable signal to check image, i had normal picture, but TV was restarting.
        I downloaded original firmware and applied the update, but the problem remained.
        From a colleague i received a "factory package software" which is a lot bigger.
        I made another firmware update, but still did not solve the problem.
        Somewhere on the way the error got worse, because at the moment the...
        08-12-2025, 12:54 PM
      • aidanmo
        Philips 43PUS7506/12 - Loud blown out sound
        by aidanmo
        I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
        I thought maybe the speakers got damaged, so I replaced them - no dice.
        • Using the internal speakers, it always happens.
        • Using the headphone jack, it never happens.
        • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
        02-28-2025, 03:13 PM
