Philips 55PFL5705D/F7 bad LCD?
  • TeeEeeKay
    • Sep 2015
    • 10
    I have a Philips LCD TV that has the symptoms pictured below. I opened up the set and reseated connectors, which didn't change the symptom. No parts have been replaced. I'm fairly certain it is a bad LCD, but I wanted to pass it by others to get their opinions.
    The pics are showing the set displaying an OTA channel with normal sound.
  • Pragmatiko
    • Jul 2013
    • 468
    • IT
    Re: Philips 55PFL5705D/F7 bad LCD?
    Seem lcd problem
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Yep my bet is failed Lcd
      • G33RT
        Philips 8200 series 65PUS8204/12 stuck at Philips Logo
        by G33RT
        Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
        It does power up when pressing the power button.
        I already try the power button while plugin the plug with no result.
        Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
        Could this be an PSU or eMMC issue ?
        07-19-2025, 03:43 AM
      • aidanmo
        Philips 43PUS7506/12 - Loud blown out sound
        by aidanmo
        I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
        I thought maybe the speakers got damaged, so I replaced them - no dice.
        • Using the internal speakers, it always happens.
        • Using the headphone jack, it never happens.
        • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
        02-28-2025, 03:13 PM
      • Cornito
        Philips 50PUH6400 bad color and gosting / slow motion on one side
        by Cornito
        Hello Team,
        New issue on LCD panel where I need to find out the cause and the potential solution.
        This is on the Philips 50PUH6400, the LCD panel is an INNOLUX V500dk2 xrs1.
        I have image, on the right side, the image is more or less normal even if there is a small blur on edge, on the left there is an issue.
        When moving up and down in the menu on the right the image is slow to disappear, and is darker, like red/brown.
        I've checked voltages, no issue found comparing right and left side of the panel driver.
        VHG VGL CKV... are the sames on...
        03-08-2024, 06:41 AM
      • spantor
        Activate power board Philips 40PFH40009/88 tv
        by spantor
        Hello partners.
        Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
        The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell...
        02-11-2024, 05:07 PM
      • nlc2000
        Philips 65OLED818/12 FZ1
        by nlc2000
        I recently installed a new SSB board (model from ASWO) in my Philips 65OLED818/12 FZ1 television after the original board failed due to a lightning strike. The TV now powers on and the Ambilight works, but there is no picture displayed.
        I believe the panel ID is TPM23.1E, but I can provide the exact panel code if needed.
        Could you provide the correct NVM.bin file for this model and panel? If there is another solution—such as firmware or service mode initialization—I would greatly appreciate your guidance.
        Thank you in advance for...
        08-04-2025, 11:46 PM
