LG 55LN5400 Jumping Picture
  • rikrikrik13
    • May 2013
    • 44
    I got this LG 55LN5400 with a jumping picture (See pictures)
    I already replaced the t-con board with one on eBay with no success
  • rikrikrik13
    • May 2013
    • 44
    Re: LG 55LN5400 Jumping Picture
    I also tried to disconnect one side of the t-con but It won't work (Should give half of the screen) at all (blank picture) if I disconnect any of the sides
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Prob the panel itself. Whenever Ive seen that double-image/lined sort of picture--the panel itself or the COF chips that are part of the panel has been duff.
      TELEFIX
      • rikrikrik13
        • May 2013
        • 44
        Is it normal if I leave the tv working for a while, the image get better and better?
        its not jumping anymore, but the image is still not good :p
        • vinceroger69
          • Mar 2012
          • 6714
          I wonder if these sets suffer from bad tab bonds? also i wonder if maybe the main board could cause this you have nothing too loose try heating the main board up with a hair dryer see if the picture gets better as maybe bad bga soldering etc.
          • CapLeaker
            Leaking Member
            • 8180
            That isn't a tab bond or tcon issue. You sure can press on the BGA, heat or cool things on the main board see what happens... but the chances are slim.
            • rikrikrik13
              • May 2013
              • 44
              30 minutes TV is running and now the picture is almost perfect ??
              • rikrikrik13
                • May 2013
                • 44
                I just did a software update, no change.
                Image still good after 45 minutes (you can still see some horizontale line everywhere but you really need to look)
                Screen seems to keep ghost image, after the update, the '' UPDATE '' message stayed on the screen for several minutes (ghost image)
                I think the panel is bad lol
                • Fly_Among_Stars
                  VIZIO E70-E3 Half picture with half TCON
                  by Fly_Among_Stars
                  I have a VIZIO E70-E3.
                  Symptoms: Black screen, no picture, but LED backlights are working.
                  I probed the power board and voltages are as listed on the board.
                  Main board appears fine, too.
                  I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                  There are two separate ribbon cables feeding the LCD.
                  If both are connected, the screen is black.
                  If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                  04-24-2023, 08:20 PM
                • shelby5041
                  Samsung LCD TV no picture backlight on no 12v at tcon
                  by shelby5041
                  hi
                  i have a samsung lcd tv
                  it powers on with sound and backlight but no picture
                  all voltages from PS are good 12v 3.3v and 5v
                  whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                  i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                  no 12v at the tcon fuse
                  i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                  the odds of having 2...
                  10-08-2021, 08:21 AM
                • x_orange90_x
                  TCL 50S535 bad tcon or panel issue?
                  by x_orange90_x
                  Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                  03-29-2025, 11:02 PM
                • Tr0ll
                  by Tr0ll
                  Original T-con:
                  First replacement T-con:
                  10-07-2023, 07:48 PM
                • JJAAMM
                  by JJAAMM
                  Problem
                  07-06-2023, 06:01 AM
