Samsung LN46A850S1FXZA vertical line
  • rs1n
    • Jan 2016
    • 12
    I have had this TV for some time now and have noticed a vertical line on the right hand side. It goes away over time (usually after 30 minutes). I have read a number of threads on this board and have come to the suspicion that it may be a bad bond tabs. A number of posts suggest that it may simply be a bad panel (seems common for Samsung) but sometimes I get 2 or 3 vertical lines (around the same portion of the TV -- the right side). The additional lines usually appear if I am attaching something into the HDMI (or other input) ports. A bit of wiggling around usually gets them down to a single vertical line. I don't mind it so much (since it goes away after the TV has warmed up). Does anyone have a diagnosis based on this description?
    http://postimg.org/gallery/noj8a6wk/
    Re: Samsung LN46A850S1FXZA vertical line
    Does it change if you flex the LCD panel?
    • rs1n
      • Jan 2016
      • 12
      How would you recommend flexing the panel? It is fairly stiff. Or did you mean flexing the spot where everything is plugged in (HDMI, VID, VGA, component, etc -- all inputs) ?
      • freakaftr8
        • Oct 2012
        • 3743
        It sounds like a faulty vertical tab bond. Sometimes using a cushion agent between the metal lcd frame and the panel will give you luck but not a permanent fix forever.This requires completely disassembling the TV and pulling the black plastic bezel frame off the front of the TV then removing the screws that hold the metal frame to the LCD panel pulling the frame back a little bit in shimming the bad tab which presses the metal frame against the tab even harder. It can evevtually come back or go to a full bar of black or even the panel itself will go dark on that side and get blurry (refresh problem).
        • Stanley1843
          Screen Display Vertical Multicolor Lines
          by Stanley1843
          Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
          06-29-2024, 11:54 AM
        • Ihandyrepair
          Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
          by Ihandyrepair
          Hi guys
          I just started fixing 4k TV few months ago. so I am still learning a lot
          I got this tv from friend complaint is ghosting or horizontal lines on image.
          never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
          then it started to show the ghosting white image.
          I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
          it has 3 thin small boards at the bottom of the...
          12-05-2022, 04:18 PM
        • x_orange90_x
          Samsung UN46C8000XFXZA vertical bars/horizontal lines
          by x_orange90_x
          I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
          The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
          09-04-2023, 12:09 PM
        • mrsith
          Samsung UE58TU7100K - no picture, vertical line
          by mrsith
          Hi.
          Got UE58TU7100K with no picture - backlight comes on though. Figured out that's a perfect candidate for cut tape method.
          This model has just one LVDS tape coming off main board - and two panel boards underneath the LCD screen are connected to each other via small tape. Like curved screens. I've tried to disconnect half of the screen (5he side without LVDS connector on it, obviously), no joy.
          Disconnected the tape (main board side). Applied a small piece of tape, covering first ~4-5 pins. Powered the TV on - got picture. In negative, but that's...
          02-07-2023, 11:18 AM
          09-07-2024, 05:50 AM
