Philips 37PFL5522D/05 bad gamma IC -- damaged LVDS cable
    Picked up one of these sets with obvious gamma IC fault with picture going white after about 10-15 seconds powered on, gamma IC getting very hot. However I was a complete idiot when taking the frame off and completely tore the LVDS cable apart. Stupid mistake, the cable is very short and is far weaker at the T-con end...
    Long shot...would anyone happen to have one of these cables? Happy to pay cost of postage and a little extra for the cable.
  • dcapper
    • Dec 2013
    • 496
    Re: Philips 37PFL5522D/05 bad gamma IC -- damaged LVDS cable
    Tom I'm on holidays for two more weeks but I have a pile of lvds cables at home. You can have one for nothing if I have one. You do so much for the community, it's the least I can do if I have one.
    Found this one on ebay:
    http://www.ebay.com/itm/PHILIPS-37PF...EAAMXQ9MVRhC3s
    http://www.ebay.com/itm/PHILIPS-37PF...8AAOxyOMdS-ibA
      Thanks for the offer, I appreciate it. I'm probably going to end up buying one off eBay but I'll be asking a friend of mine who deals with TVs a lot too.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Unlucky Tom did it have glue on it ? I will check my bag of wires for you mate. Ive done that once on a Vestel set that had copious amounts of glue on the wire.
          Yep, it was glued on the T-con end, which probably explains why it didn't just disconnect.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Its shit when they do that Will let you know tomoz mate as I parted out quite a few phillips sets and kept the wires.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Have you got a cable Tom I dont have one sorry ?
              • NolesFan
                Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                by NolesFan
                Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                10-24-2024, 06:36 PM
              • G33RT
                Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                by G33RT
                Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                It does power up when pressing the power button.
                I already try the power button while plugin the plug with no result.
                Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                Could this be an PSU or eMMC issue ?
                07-19-2025, 03:43 AM
              • XxMicroSoldering
                ASUS Rog Strix G17-712LV Laptop Liquid damaged
                by XxMicroSoldering
                Hello Guys
                I have a ASUS Rog strix laptop that I bought recently to fix and the previous owner spilled water on it . He brought it into a repair shop for them to check it out and instead of fixing it they damaged the battery connector of the laptop ! Other than that they damaged damaged nothing . But since the liquid damage the laptop only turns on and the keyboard lights up and then immediately turns off. I really want to repair this laptop and I also have experience in repairing phones etc and laptops and a bit of soldering but the diagnosing part is where I need help with and...
                10-17-2024, 10:45 AM
              • double_DD
                Philips curling iron - is this a common AC cable?
                by double_DD
                Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                Yesterday, 10:04 AM
              • janos6662000
                Philips 47PFS7509/12 LCD TV problem
                by janos6662000
                Hi
                I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                When i applied cable signal to check image, i had normal picture, but TV was restarting.
                I downloaded original firmware and applied the update, but the problem remained.
                From a colleague i received a "factory package software" which is a lot bigger.
                I made another firmware update, but still did not solve the problem.
                Somewhere on the way the error got worse, because at the moment the...
                08-12-2025, 12:54 PM
