Sony kdl-50w656a no picture
  • andrews7523
    • Apr 2015
    • 117
    • lancashire
    I have a SONY KDL-50W656A what i bought thinking might need a new tcon board as the tv lit up without picture but later realised this set didn't have a t-con board. I found a donor which was smashed so started off replacing the main board which had no effect. Im thinking that maybe this is the wrong main board as I've seen this happen before. A lot of tvs i buy come from repair centres and can be left with incorrect parts being fitted. Any ideas how to help
    Re: Sony kdl-50w656a no picture
    Are you saying that the T-CON board is missing or the the LCD panel has an integrated T-CON? But no matter what kind, it still need switched the switched 12VDC to run the T-CON.
    • andrews7523
      • Apr 2015
      • 117
      • lancashire
      integrated tcon. i know the main board works as I've tried it in the donor which has a damaged screen
      • fliperek
        • Poland
        hi,
        I have the same problem with my tv the same model, sound works, but no picture, backlight also works, did you solve the problem? what was the reason? which parts did you replace or repair?
        • andrews7523
          • Apr 2015
          • 117
          • lancashire
          common fault rubbish tvs bin it
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • gersrt
            Ordered Wrong TCON Board For Sony TV, Can I flash Epprom
            by gersrt
            HI
            Made a mistake and ordered the wrong TCON board to replace in my KDL-46HX823, the board I ordered was Sony PLY 1-883-893-11 which is sort of correct.
            But later realized this board is used in 4 or 5 models, any way the one i got sent was for KDL-55HX820.
            Physically these boards are identical, everything on the board is the same. I havent put this board into the TV yet, but am I right in saying all i would have to do is copy the Epprom from my faulty board and transfere it on to the new board, or is there still something else that may stop this working....
            01-27-2021, 05:49 PM
          • TerraPhantm
            Sony A8H to A80J mainboard upgrade possible?
            by TerraPhantm
            I have a Sony 65A8H. Always bothered me that it doesn't have HDMI 2.1. I noticed the A80J board appears quite similar. And comparing some wiring diagrams in the service manuals (albeit A9G vs A90J since I couldn't find the A8/80 manuals), things appeared quite similar. And my understanding is the panels between the two TVs are more or less the same.
            So I decided I'd experiment a little bit.
            I bought an A80J board. Left the speaker connection unplugged because it doesn't fit. Changed the power connector to fit the new board. Plugged in everything else.
            When...
            08-15-2023, 08:10 AM
