Sony TV, KDL-55EX621, white/grey screen with lines
  • tictac
    • Nov 2014
    • 26
    I have this 55" Sony LCD with a video problem. The sound seems ok and the screen lights up but there is no picture data. The screen has large blocks of gray & white with darker horizontal bands scrolling upwards. See the photo below. If anyone has any suggestions, please let me know what other info is needed. Thank you in advance.
  • zomi
    • Nov 2011
    • 505
    Re: Sony TV, KDL-55EX621, white/grey screen with lines
    looks like panel failure.
    Bright band looks like maybe liquid damage on the tab, from cleaning maybe
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Panel failure likely not fixable
      • tictac
        • Nov 2014
        • 26
        Would this mean that the boards are still likely to be good?
        • tictac
          • Nov 2014
          • 26
          Does that mean the boards are still good?
          • dcapper
            • Dec 2013
            • 496
            Don't know about the tcon but the other should be ok.
            • Chrissygizmo
              Sony KD-55XG9505 lines on screen problem
              by Chrissygizmo
              Hello again everyone,
              This is my latest mission, to try getting this Sony tv back to normal working order…
              I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
              02-19-2025, 11:31 AM
            • ggil44
              Sony XBR-65X750D Horizontal lines bottom of screen
              by ggil44
              Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
              05-30-2023, 07:51 PM
            • Daren87
              Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
              by Daren87
              I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
              08-13-2023, 03:25 PM
            • Ihandyrepair
              sony 55X850D black screen no front white or red led light.
              by Ihandyrepair
              Hi guys
              strange one
              I have a dead Sony 55X850D
              when plug in, black screen, no front white or red LED, no back light no screen
              Voltages I get
              3.3v LD/power and main board
              reg 12V
              reg 19V
              3.3v on power on pin
              no Tcon on
              no tcon 12v
              no BL_on
              I do get BL_ERR 2.0v
              I tried to bypass it by ground it but still get same symptom
              I did also found a possible shorted cap on main board as it is showing 10 ohms when measure with meter
              or is possible the chip next to...
              08-07-2024, 04:58 AM
            • Stanley1843
              by Stanley1843
              06-29-2024, 11:54 AM
