Yet Another TC-P55GT30 7 Blinking Light Error
  • syaoran123
    • Jun 2014
    • 178
    Re: Yet Another TC-P55GT30 7 Blinking Light Error
    Originally posted by JeffJ
    Made it to the 2 hour mark with Q401, 402, 403, 421, 422, and 423 using FGB20N60SFD IGBT.
    Temperature around 45C still.
    Will see if it makes it to the end of this 10 hour video.
    Still going?
    • johnboy1313
      • Nov 2012
      • 1959
      I would turn it on and off several times while the video plays.
      • JeffJ
        • Apr 2012
        • 189
        Originally posted by syaoran123
        Still going?
        I shut it off after 5.5h yesterday. It would be careless to leave a TV i expect may fail running in an unoccupied shop overnight. I will start the test again when i arrive in my shop today.
        As for turning it on and off, I can also do this as well. With the sweeping patterns video, i monitor how many watts it is drawing while doing so to see if i can get to its peek wattage draw, and i can when a full white screen is displayed.
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          #84
          As Johnboy says , turn it on and off several times a day and see what happens.
          • JeffJ
            • Apr 2012
            • 189
            USing the TV right now to test some satellite recievers i have repaired. Checked panel hours about 10,400 hours and it has been powered on and off 5040 times.
            Lets see if this lasts this day of me using it and turning it on and off.
            • JeffJ
              • Apr 2012
              • 189
              I set my smart watch to vibrate every 10 minutes today and put a documentary on loop on the youtube.
              Every 10 min i turn the tv on and off.
              This beast is still going..... wtf
              • Moreno83
                • Jun 2014
                • 2008
                • The Netherlands
                #87
                Maybe you are lucky!
                • JeffJ
                  • Apr 2012
                  • 189
                  maybe i wish i had the equipment to test how many amps those circuits peek at, who knows maybe these parts are in spec.
                  • flocko
                    • Nov 2012
                    • 1121
                    • uk
                    #89
                    Why all the fuss over these IGBTs? it seems to me Shopjimmy were also having supply problems with the GT30F131s and have just chosen a different replacement the FGB20N60, you can be sure they would have run tests using it, before adding it to there repair kits.I ran long tests using the FGD4536TMs on my refurbished board before offering them for sale.
                    • JeffJ
                      • Apr 2012
                      • 189
                      The fuss was the Peek/Pulse Amperage values been so different by a extreme from the OEM IGBTs specs. The first users has his pop relatively quick.
                      Which lead them to be suspect, However I received the kit and used them and so far I'm having no issues. So I can only deduce that the circuit never reaches the peek/pulse collector current the OEM IGBTs were rated for and these parts are suitable and the other user had other faults causing failure again, I am really lucky, or magic?
                      Since this isnt a J.K Rowling novel, I'll have to go with the parts are in fact suitable, that would be the most logical answer.
                      • flocko
                        • Nov 2012
                        • 1121
                        • uk
                        #91
                        You are not reading the data correctly, they would not be my first call as replacements but are up to the job. With all repairs to this type Panasonic SC/SN board, replacing the driver ICs and transistor arrays is a must, if theses have failed or not, they will be damaged.Then its only a matter of time for them to fail and take out the IGBTs once more.
                        • JeffJ
                          • Apr 2012
                          • 189
                          thanks for the Info. appreciated a lot.
                          I just replaced the IGBTs, and had sucess just doing thm before. I have a TC-P55GT30 at home that has been running for 3 close to 4 years now with just replacing the IGBTs. Think i should pull the board back out and do the resistors.
                          R401 402 403 421 422 and 423, as well as IC502, Q531, D401 and D423 that the kit also provides?
                          Panel has roughly 10,000 hours on it, if that makes a difference.
                          • syaoran123
                            • Jun 2014
                            • 178
                            I'm suspecting shopjimmy are selling copies because I had a customer come back a month later. And when I reordered again and installed, the TV blew immediately.
                            I would guess there are good copies mixed in with defective ones. That explains why there's mixed reviews.
                            • Moreno83
                              • Jun 2014
                              • 2008
                              • The Netherlands
                              #94
                              If Flocko says these parts will do the job then i believe him but just looking at the datasheets i would not have picked them.
                              No , the repair kit just comes with those items but RF1501/DAF30A and the resistors dont need to be replaced. The diodes only read short because the fets are shorted.
                              I agree with Flocko on the IC and transistor. These take a big hit when the board blows , i always replace them since i had blowing boards
                              • JeffJ
                                • Apr 2012
                                • 189
                                So you think i should tear it down and replace IC502, Q531 then?
                                • flocko
                                  • Nov 2012
                                  • 1121
                                  • uk
                                  #96
                                  Most do not buy kits,and just replace what they think will get the set running again, this is not always the way to go, and why if you buy a kit of parts would you not fit them all.( a good kit will have all the parts supplied that you could find blown or damaged, they are not put in the kit for fun,or to get rid of extras part that they have laying around in the workshop)There are no short cuts to a good repair if you want it to last and work first time
                                  • JeffJ
                                    • Apr 2012
                                    • 189
                                    I know this is an old thread, But the IGBT's are dead on my set again, I suspect due to the power issues we had with the ice storm. I took the board out and indeed the SC is shorted i remove the IGBT's and its not shorted any more. Same as before. Can any one help me source some IGBTs from digikey. Shop Jimmy takes quite some time to get to me.
                                    I took a look but im not confident enough to pic a suitable replacement in the active stock.
                                    • Moreno83
                                      • Jun 2014
                                      • 2008
                                      • The Netherlands
                                      #98
                                      You need these:
                                      https://www.ebay.com/itm/30PCS-PDP-P...QAAOSwIrNWFD7h
                                      • JeffJ
                                        • Apr 2012
                                        • 189
                                        Is this considered a reputable seller? I've had nothing but bad luck ordering parts from china they always seem to be fakes.
                                        • Moreno83
                                          • Jun 2014
                                          • 2008
                                          • The Netherlands
                                          #100
                                          I ordered from him and had no problems. But that was nov 16 and still use the parts as i bought them in big quantity.
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • YasaCh
                                            Sony kdl 40p5500 red light keeps blinking 3 times
                                            by YasaCh
                                            Hello...
                                            my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                            i opened the back cover no sign of damage on the powery suply or motherboard
                                            when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                            another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                            07-07-2025, 11:53 AM
                                          • pc_okay
                                            LENOVO IdeaPad 3-15ALC6 - 82KU (board NM-D521) blinking continuously 0.5A
                                            by pc_okay
                                            Hello friends,
                                            I have this laptop AMD Platform starting & not posting, fan spinning.
                                            When i press power button, the board get almost immediatly 0.5A ~ and board get stuck at 0.5A with power button led blinking indefinitly.
                                            If i stop the computer (pressing 5s power button), board stop and when i restart i get approx 0.37A ~ and
                                            I try to reflash the bios with no luck, same result, and i try disabling onboard ram (i remove resistors accordling schematic), no more progress.
                                            CPU and his area heat, maybe the cpu is dead?
                                            10-21-2024, 10:23 AM
                                          • Fergal22
                                            Samsung UE40F5300AK blinking red light
                                            by Fergal22
                                            I have the above tv that just shows a red light blinking twice 5 times, i have taken the back off and all the capacitors seem ok,
                                            When i disconnect the mainboard from the PSU all the led's light up blinking fast but as soon as i reconnect the mainboard back to the power supply i get the red light blinking again twice 5 times,
                                            I have attached pictures of the Mainboard, PSU and a small video (zipped) showing what happens when i disconnect the lead from the psu
                                            Any help would be appreciated...
                                            02-02-2023, 09:19 AM
