Magnavox 26MD301B/F7 Volume/Buttons issue
+ More Options
Posts
  • eagle00799
    • May 2012
    • 322
    Hello Everyone, Good to see this site up and running again. I have a Magnavox 26MD301B/F7 when I plug it in it comes on and the volume bar comes on the screen and turns itself down to zero. All buttons do not respond. The picture itself is fine but can't get volume to go up and stay up. Any ideas would be very helpful.
    Posting rules say I am unable to post attachments, not sure why that is as I have posted them before but I will try to get something up here if possible.
  • eagle00799
    • May 2012
    • 322
    Re: Magnavox 26MD301B/F7 Volume/Buttons issue
    Anybody have any idea's to which board or a component to check?
    • vinceroger69
      • Mar 2012
      • 6714
      i had this issue a few days ago it turnred out it was a faulty momentry switch which was stuck closed what type of switches does the button board use?
      • eagle00799
        • May 2012
        • 322
        They are push buttons, that is what it acts like but when I push the buttons they feel like they are free.
        • vinceroger69
          • Mar 2012
          • 6714
          mine felt good too but when tested with a multi meter it was showing a reading when it should of shown open circuit maybe worth taking readings on yours these are the ones in my set that was faulty
          http://www.ebay.co.uk/itm/2812450898...%3AMEBIDX%3AIT
          • R_J
            • 9576
            Disconnect the cable going to the buttons and see if that corrects the problem, if it does then change the button or better yet all of them.
            • ZnsaneRyder
              • Oct 2015
              • 88
              • Merica
              Swap them out with some replaced buttons. I fix those on TVs all the time, it is a common failure.
              Some buttons are 2 pin, 4 pin, or 5 pin (grounded) but they are mostly standard and can be salvaged from the buttons from other tv's including CRT.
              • eagle00799
                • May 2012
                • 322
                Exactly what I did, and it's now working perfectly. Thanks a bunch guys!
                • zklgfs
                  Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                  by zklgfs
                  I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                  08-11-2025, 02:14 PM
                • BigOof
                  Marantz SR5007 popping on volume change and mute in Direct Mode
                  by BigOof
                  I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
                  12-12-2024, 06:15 AM
                • rounin
                  MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                  by rounin
                  🛠 Original Issue
                  ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                  04-19-2025, 01:18 AM
                • gilbert009
                  I need help identifying the issue with my Magnavox MDR513H dvd recorder!
                  by gilbert009
                  Hello! I am fairly new at repairing electronics. Recently I came across an old Magnavox MDR513H dvd/hdd recorder. It is not powering on. When the unit is plugged in, I get this really annoying beeping sound coming from the power supply.. I have already tried things like unplugging the unit for a few hours, holding the power button for a minute or 2. Nothing seems to make It work.
                  I found this guy with the same problem on YouTube -https://www.youtube.com/watch?v=iFVm-SJX-S8
                  I checked all over this video's comments but no one really helps him with the issue. except...
                  12-01-2021, 04:04 AM
                • ugamazing
                  by ugamazing
                  12-17-2024, 07:05 PM
