Samsung LN40B640R3F -- standby voltage slowly drops/drains to zero
  • gnuorder
    • Feb 2016
    • 19
    Re: Samsung LN40B640R3F -- standby voltage slowly drops/drains to zero
    Originally posted by budm
    It must be measurement error, Collector of QB801 is the input, the Base is connected to the Zener diode/diode and biased through the RB814 and OPTO PC802S, the Base Voltage cannot be higher than Collector Voltage, if the Collector is 0V then there will be no output at the Emitter of the QB801.
    The setup is just a simple linear regulator with OPTO used as a switch.
    You should check the solder joint of the transistor, OPTO, and the connection from the Collector all the way back to diode DM802.
    http://www.radio-electronics.com/inf...ry-circuit.php
    I did assume the middle connector of the transistor was the base so those may be reversed. Looking at the photo pjs2015, they are reversed and I found the opto. Solder connections look good for all but the opto which I haven't checked yet.
      Middle pin is Collector.
      KTD1347.
      • gnuorder
        • Feb 2016
        • 19
        So if the collector is going to 0v, the opto is switching off. I should measure the voltage between rb814 and rb815 to verify that it's shutting off.
          The Voltage should always be present at the Collector as long as there is AC feeding the TV, the Voltage is generated by the standby power supply power transformer, see circuit for details. I would check the DCV between the two legs of the filter cap CM804, check diode DM802, RM806, solder joints.
          • gnuorder
            • Feb 2016
            • 19
            The voltage across CM804 was 8.89 but was slowly dropping, 8.50 last check. The voltage across RM806 was 0v.
              That cannot be right, if it that low, the standby power supply will not be running since the shutdown Voltage for the stby IC UM801S (STRW6252) is around 8~9.8V. I expect the DCV on CM804 to be around 18V or so.
              Must be error reading.
              You do have stndby Voltage, right?
              • gnuorder
                • Feb 2016
                • 19
                Apparently not. I measure 0v at the connector between pins 3 and 4.
                  Wait a minute!
                  So this is no longer true? The standby must have been working before.
                  I'm getting back to this TV. I'm getting 14.5v at the QB801 emitter when it's working and 0.22v when it's not.
                  I'm still confused about the two zeners in series. I only see one zener ZB802 and one diode array DB802. I ordered replacements for both. We'll see how it goes. Did you have any luck?
                  • gnuorder
                    • Feb 2016
                    • 19
                    Wait a minute!
                    Yes, that is true. When I started working on it today I was getting close to 15v off the emitter, now I'm getting 0.23V. I can let it sit for a while and start again. It will have to be tomorrow though.
                    • gnuorder
                      • Feb 2016
                      • 19
                      Sorry it's been a while before I could get back to this. I measured today to remind myself. At first I have stb but it goes to 0 after I turn on the TV. It use to be slow but now much quicker. When I first plug the TV in, I get 5.15 at stb and it seems stable. Once it shuts off, I can't get stb to come back unless I unplug it a while. First plugged in today, I got 5.15v at stb, .22v at the emitter of QB801, 17.2v at the collector and 0 at the base. When I power on I got 15.35v at the base, 9.1v and dropping at the collector and .37v at the emitter. By the time I got to stb, it was at .15v so it's dropping much faster now. I measured CM804 between ground and DM803. Wait, I take that back. I have been measuring at DM802 thinking it was DM803. I just found DM803 so I'll have to retest the collector voltages after I let it sit for a while. I'm getting a stereo scope soon to make this easier. My eyesight is getting bad.
                      • gnuorder
                        • Feb 2016
                        • 19
                        Wait, I take that back. I have been measuring at DM802 thinking it was DM803. .
                        Never mind, they are common.
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          #32
                          What voltage do you have across CM808 (22uF 50V cap) when you lose 5VSTB?
                          • gnuorder
                            • Feb 2016
                            • 19
                            It fluctuates between roughly 13v and 10v. Also, I don't get 5vstb at all any more.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4458
                              • Italy - Milan
                              #34
                              Hi, i don't have seen circuits, nor followed your measurements, but i suggest you to replace el.caps on the secondary side, first to the standby circuit then to rest if it doesn't fix, el.caps can go short under load sometimes, psu goes in protection and you see voltages go down slowly on caps..
                              • gnuorder
                                • Feb 2016
                                • 19
                                I get a brief voltage between DM802 and RM806 but that drops to zero. I still get around 8v on the other side of DM802. I can no longer get stb to come on even after letting the TV sit unplugged. I replaced CM804 and CM808 even though they didn't seem bad.
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4458
                                  • Italy - Milan
                                  #36
                                  i told about changing el.caps on the secondary side...
                                  • tvguy12012012120
                                    by tvguy12012012120
                                    02-07-2025, 05:13 PM
                                  • fharris1977
                                    Vizio D50u-D1 Dead Set No Standby
                                    by fharris1977
                                    Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                    12-28-2023, 10:25 AM
                                  • Crystaleyes
                                    Samsung BN44-00259A standby question
                                    by Crystaleyes
                                    Hi all.
                                    I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                    SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                    Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                    The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                    08-11-2023, 05:15 AM
                                  • Beeldbuisje
                                    MBP 13" A1708 820-00840A drains battery in Standby
                                    by Beeldbuisje
                                    Laptop was completely dead, cool vent full with dust, cleaned, reflowed CPU and worked fine again since January.
                                    Working on this machine gives a battery life time of +/- 8h, cycle count 908, but the battery gives "normal" status in MacOS.
                                    Clean install of BigSur, last version. But, when flipping down the screen, the system should go to standby mode.
                                    When you try to wake it up, it takes some seconds, so it seems he's indeed in standby. But after +/-2 days, the battery is completely empty.
                                    Looking on activity monitor, shows an abnormal battery...
                                    05-11-2021, 05:31 AM
                                  • spleenharvester
                                    Whirlpool PACF212HP W portable air conditioner, upper fan only turns slowly.
                                    by spleenharvester
                                    I just acquired this portable aircon, history unknown. Its behaviour is quite strange:
                                    • When turned on and placed into cooling mode, the upper fan (cold air out) just spins slowly. The compressor and lower fan do not run.
                                    • If the device is then placed into heating mode and then back into cooling mode, the lower fan and compressor kick in and start cooling, but the upper fan still only spins slowly.
                                    • If the device is placed into fan-only mode, the upper fan does not respond to low/medium/high speed toggles - just keeps running slowly.
                                    • Display and buttons all behave normally aside from the
                                    06-27-2025, 07:49 PM
