MBP 13" A1708 820-00840A drains battery in Standby
  • Beeldbuisje
    • Jul 2020
    • 57
    • Belgium
    Laptop was completely dead, cool vent full with dust, cleaned, reflowed CPU and worked fine again since January.
    Working on this machine gives a battery life time of +/- 8h, cycle count 908, but the battery gives "normal" status in MacOS.
    Clean install of BigSur, last version. But, when flipping down the screen, the system should go to standby mode.
    When you try to wake it up, it takes some seconds, so it seems he's indeed in standby. But after +/-2 days, the battery is completely empty.
    Looking on activity monitor, shows an abnormal battery drain sometimes. Sometimes a flat line, sometimes for hours a going down line.
    A complete shutdown and the battery keeps fully charged.
    SMC en PRAM are reset.
    Any experiences with this behavior?
    tnx
    Gert
  • mon2
    • 14617
    Re: MBP 13" A1708 820-00840A drains battery in Standby
    908 battery cycles is a very long life. At best, the official Apple battery is rated at 1000 cycles (projected).
    Try another (fresh) battery.
    • Beeldbuisje
      • Jul 2020
      • 57
      • Belgium
      Jep, I know, but while working on this laptop the power consumption is higher as in standby.
      With a bad battery, you should expect a shorter working time.
      There are already a lot of parts changed on this device (LCD under warranty, SSD, keyboard). I have to be sure before ordering a new battery.
      • Beeldbuisje
        • Jul 2020
        • 57
        • Belgium
        Discovered the issue, but I'm afraid it isn't solvable...
        The SSD has been changed in this machine by an adapter and a 2242 NVMe.
        I've got another A1708 last week. Changing the SSD's changes the problem.
        It seems there're no workarounds available to solve this issue.
        • kalilinux25
          • Mar 2018
          • 2089
          • ZAMBOANGA SIBUGAY
          If I install a new battery should I perform battery reset first? and how to enable to do the reset also thanks
          • Beeldbuisje
            • Jul 2020
            • 57
            • Belgium
            I've always charged the new battery till 100%. Next, working on the computer till it drops till 10% and finally let it charge again till 100%.
            All the macbooks where I've changed the battery worked fine after this principle.
            • kalilinux25
              • Mar 2018
              • 2089
              • ZAMBOANGA SIBUGAY
              Those it not require to smc reset because sometimes it will stop at 45% then sometimes full then somtimes if you let it stanby it looks like its jumping to 45% again
              • Beeldbuisje
                • Jul 2020
                • 57
                • Belgium
                it could take time, but normally it should calibrate itself.
                Resetting SMC and PRAM is always a possibility. It doesn't has a disadvantage...
                • kalilinux25
                  • Mar 2018
                  • 2089
                  • ZAMBOANGA SIBUGAY
                  Its my first time that's why Im having troubke ubderstanding this type of units
                  • soufeer
                    • Dec 2020
                    • india
                    A1708 820-00840A PPVCCGT_S0G is present but no PPVCCCPU_S0G
                    • Bowline
                      by Bowline
                      06-11-2025, 10:13 AM
                    • mkdj
                      by mkdj
                      Mark and model: ASUS X571
                      Tests already made:
                      - I have removed...
                      07-14-2025, 09:16 AM
                    • techfreak9356
                      Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                      by techfreak9356
                      09-14-2023, 11:10 PM
                      NVDC charger configuration...
                      11-05-2024, 03:28 PM
                    • ferah831208
                      by ferah831208
                      03-18-2025, 01:18 AM
