Philips 42plf5332d/37 backlight strobe
  • Dcourtwreck
    • Apr 2013
    • 6
    • US
    Video here:
    https://www.youtube.com/watch?v=GVV4...ature=youtu.be
    If I leave the tv unplugged for weeks it might work properly for a couple of days, then the strobe returns. I didn't see any bulging caps or leakage on the power supply board. I should have taken some photos when I had it apart, but I'll go back and snap a few if I am able to get any replies here.
    With the limited info I have provided so far... is it sounding more like an inverter issue or a power supply problem?
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Philips 42plf5332d/37 backlight strobe
    Hmm--Not heard of the model number--
    Are you sure its not 42PFL5532...?
    Pics of the Internal boards will help, I suspect its the PFL Plasma set--ie, no inverters...
    TELEFIX
    • Dcourtwreck
      • Apr 2013
      • 6
      • US
      42pfl5332d/37
      My mistake, I typed the model number incorrectly. It's an lcd set. I'm going to try and take some pictures this afternoon.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8326
        smart dimming acting up?
        • Dcourtwreck
          • Apr 2013
          • 6
          • US
          Dynamic Contrast? I have it turned off.
          • Shinju
            • Mar 2014
            • 1239
            I had a Phillips ambilight LCD do this after replacing the inverter slave/master inverter boards. I had brightness all the way up to solve it temporarily but I think it was something to do with with Eco setting active dimming backlight sensor that failed on the mainboard.
            • howardc64
              Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
              by howardc64
              TV was fixed just after removing Samsung's rear snap cover.
              This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
              Maybe PSU->backlight connector didn't have a good contact?...
              07-23-2025, 12:34 AM
            • chestercc
              Philips TV Backlight Repair
              by chestercc
              So i'm trying to replace the LED's in a Philips TV. It's 42" with a 715g7262-p01-000-0010 backlight driver board based around an O2 Micro OZ9902CGN.
              My issue is when I replace all the LED's on one board with the new 3V 300ma ones they immediately burn out when the set is powered again. I previously tried the same thing with 6V LED's and the backlight flickered for a bit but wouldn't start.
              The original LED's which I removed which are still working start to melt and burn when given more than 3V on DCPS so I know they shouldn't be higher voltage ones.
              11-18-2022, 01:15 PM
            • ohren
              Trying to control Philips backlight manually with PWM — brightness increases with frequency...?
              by ohren
              I raised the question of whether PWM on the power board "dim" pin would be a reasonable assumption for controlling the backlight of a Philips TV (55put6101/12): https://www.badcaps.net/forum/troubl...d-tv-backlight. I didn't receive any insights there so I went ahead and tried it.
              The setup is basically:
              Rpi3 hardware PWM → 220 Ohm → NPN transistor → dim pin
              Transistor is switching the 3.5 V supply on the power board....
              12-05-2024, 11:10 AM
            • ovrax
              Philips 55PUS6804/12 turn on & off (probably backlight issue)
              by ovrax
              First of all, please excuse me as I'm quite new to this field.
              I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
              I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
              The Ambilight works perfectly and stays on.
              No sounds.
              Thanks in advance.
              08-25-2024, 04:33 AM
            • triplefour
              by triplefour
              09-13-2023, 10:43 PM
