17PW15-9 Horrible Buzz From Pfc Help ?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: 17PW15-9 Horrible Buzz From Pfc Help ?
    Originally posted by flocko
    Be sure to put on your hard hat and safety goggles, these Vestal boards are known to put up a good fight, and do not like to get beat
    • michael dranfield
      • Jan 2016
      • 232
      • England
      Just done one of these today with same fault, the 360V is far to low, you should be measuring 385v with the set running, replace the 3 x smd resistors in the PFC feedback as the old ones fall in value BUT clean the pcb before you put new resistors in as surface leakage here can have the same effect as the resistors falling in value, simply replacing them without cleaning the pcb is not good enough.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        I did that and the issue was not solved, I ended up replacing half the PFC parts off another board that had blown up in a different way still not solved so I replaced Psu and the Tv worked. This board ended up meeting the hammer.
        • flocko
          • Nov 2012
          • 1121
          • uk
          And a job very well done may I say, Vestal shit spreading at its best
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Haha cheers
            • aidanmo
              Philips 43PUS7506/12 - Loud blown out sound
              by aidanmo
              I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
              I thought maybe the speakers got damaged, so I replaced them - no dice.
              • Using the internal speakers, it always happens.
              • Using the headphone jack, it never happens.
              • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
              02-28-2025, 03:13 PM
            • justice171
              Lenovo E15 Gen 2 Keeps Beeping Loud Noise
              by justice171
              Hello Badcaps Members,
              I'm experiencing an issue with my Lenovo ThinkPad E15 Gen 2, and I'm hoping someone here might have some insight. The laptop charges to full capacity, but as soon as I power it up, I get a loud sound, and there's no POST.
              I disconnected the battery and connected a USB meter, which shows 20V 0.23A when the sound occurs. I've already tried changing the screen, but it didn't resolve the issue.
              When I use Lenovo PC Diagnostics App I get results as 01000
              Here are the details:
              • Model: Lenovo ThinkPad E15 Gen 2
              • Board Numbe
              10-01-2024, 09:19 PM
            • eliemgh
              lenovo t14 i7 10 gen : I press the power button and there is a loud fan noise
              by eliemgh
              lenovo t14 i7 10 gen : I press the power button and there is a loud fan noise for about 3 seconds and power light is on. Nothing on display screen. i have removed the battery and bios battery still the same. i have put yesterday on update and charger ,i have leave and back and see this problem. Any One Can help Me ?
              09-27-2024, 02:40 AM
            • Carm99
              Citronic AC-1USB Output Too Loud
              by Carm99
              Hi
              I have a Citronic AC-1USB.
              When I run a turntable into it and then try to record it. The volume is too loud and distorting. In the red. Mainly 12” Singles. I haven’t tried a CD into it yet. I’m wondering if there is any way to bring the volume down inside the unit itself. Change a part or two. Put a small pot somewhere as there are no adjustments at all in there. I’m looking for the schematic but not found one yet.
              Heres the circuit board inside.
              Cheers
              04-30-2024, 06:17 AM
            • Alika Salazar
              820-02020 macbook pro m1 loud fan speed - HELP!
              by Alika Salazar
              i’ve got a macbook pro m1 here with loud fan speed on boot up. prior liquid damage but minor. under scope i see slight liquid damage in area of RT860 & CT702
              ive tried trackpad and trackpad cable still didn’t fix
              i’ve checked thermal to see if any heat, nothing.
              any help appreciated!!
              03-11-2024, 03:41 PM
