17PW15-9 Horrible Buzz From Pfc Help ?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    This Psu is close to meeting the hammer.... Tv come in with loud obnoxious buzz coming from the back. Found the Psu to be the cause, the buzz is coming from TR806 which is the Pfc transformer I have replaced the following and the issue still persists:
    Every lytic cap on the Psu including the primary
    Poly caps C878, 877
    Ic828 LM317T
    TR806 (off another board)
    Q803 Pfc mosfet
    D824 Pfc diode
    Ic802 Pfc controller
    R817, 818, 819 Pfc resistors
    R807,806 (looked burned)
    Resoldered alot of devices
    Nothing is S/C
    After doing this it seems the buzz is intermittent either ways its very loud, Pfc is at 360 which is a little low but not too bad. All output voltages are stable and the Tv works. Any ideas before I replace yet another one of these junks ?
  • victor_cj
    • May 2015
    • 90
    Re: 17PW15-9 Horrible Buzz From Pfc Help ?
    Replace R805, R806, R807 1% tolerance and C890, C802 with other new.
    The art of fighting without fighting
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Cheers will give it a blast.
        360 too low, needs to be 390V. The PFC will be dropping out under load and you will be getting peak currents flowing thru PFC inductor
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Right replaced them parts no luck The Pfc is quite low, I have had others that do work at this voltage though, at 330v (on 240v ac) they fail Tom. I just can never solve this issue, any time I replace these boards is when the Pfc is bad.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Any suggestions ?
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              I just dont get it, nothing tests out of whack all the little smd and larger resistors check good as well as the smaller ceramic caps (they normally fail S/C) any help is appreciated cheers !
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Right off to bed now lol what I might do is remove the Pfc all together see how well it runs, it is possible by removing the mosfet, diode and controller, if not can get a board for £15
                • flocko
                  • Nov 2012
                  • 1121
                  • uk
                  I understand the need to repair, but looking at the list of parts that you have replaced and your time, and the fact that a replacement can be had for £15.you need to know when to stop trying to save this shit. Buy the the board for £15 fit it with nice new caps then send the set on its way, happy that you done your best. That could be your new years resolution ?
                  • rievax_60
                    • May 2012
                    • 897
                    • australia
                    Q823 is a protection transistor. Is it being pulsed on?
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Not too sure buddy will give it a shot.
                      • rievax_60
                        • May 2012
                        • 897
                        • australia
                        Sometimes surface mount resistors can decrease in resistance in high voltage areas.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Decided to replace the board, simply not worth my time, something stupid is at fault here. Going to take my caps back and smash it up lol
                          • rievax_60
                            • May 2012
                            • 897
                            • australia
                            Before you do. Take a reading of R926, R927, R928. Check them in circuit before any soldering is done. Look for a difference in reading. Are they surface mount?
                            I know it's a long shot.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Ok will do tomorrow buddy cheers.
                              • flocko
                                • Nov 2012
                                • 1121
                                • uk
                                Smash it up and move on, the satisfaction will help you to deal with not all ways being able to fix every thing ? just a little bit of Flocko therapy
                                  It's more fun to connect the bulk capacitor to 230V AC directly and stand back.
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    Replaced them and didnt work, now its going to suffer for wasting my time
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Also got a few other Vestel boards that need a meeting with the hammer so they can join too.
                                      • flocko
                                        • Nov 2012
                                        • 1121
                                        • uk
                                        Be sure to put on your hard hat and safety goggles, these Vestal boards are known to put up a good fight, and do not like to get beat
                                        • aidanmo
                                          Philips 43PUS7506/12 - Loud blown out sound
                                          by aidanmo
                                          I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                                          I thought maybe the speakers got damaged, so I replaced them - no dice.
                                          • Using the internal speakers, it always happens.
                                          • Using the headphone jack, it never happens.
                                          • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                                          02-28-2025, 03:13 PM
                                        • mon2
                                          Crate guitar amp with extremely loud static on power on (no input)
                                          by mon2
                                          Hi. Not our mainstream line of work - we work with digital mostly. Will study the schematic found on the internet. The output darlington transistors appear to be ok. Even with no input, the output is extremely loud with static / crackle / pop. Any ideas? Will post more details and fix as we continue the review. Have not checked the main power supply rails yet (+-40V and +-16V).
                                          07-18-2025, 06:40 AM
                                        • justice171
                                          Lenovo E15 Gen 2 Keeps Beeping Loud Noise
                                          by justice171
                                          Hello Badcaps Members,
                                          I'm experiencing an issue with my Lenovo ThinkPad E15 Gen 2, and I'm hoping someone here might have some insight. The laptop charges to full capacity, but as soon as I power it up, I get a loud sound, and there's no POST.
                                          I disconnected the battery and connected a USB meter, which shows 20V 0.23A when the sound occurs. I've already tried changing the screen, but it didn't resolve the issue.
                                          When I use Lenovo PC Diagnostics App I get results as 01000
                                          Here are the details:
                                          • Model: Lenovo ThinkPad E15 Gen 2
                                          • Board Numbe
                                          10-01-2024, 09:19 PM
                                        • eliemgh
                                          lenovo t14 i7 10 gen : I press the power button and there is a loud fan noise
                                          by eliemgh
                                          lenovo t14 i7 10 gen : I press the power button and there is a loud fan noise for about 3 seconds and power light is on. Nothing on display screen. i have removed the battery and bios battery still the same. i have put yesterday on update and charger ,i have leave and back and see this problem. Any One Can help Me ?
                                          09-27-2024, 02:40 AM
                                        • Carm99
                                          Citronic AC-1USB Output Too Loud
                                          by Carm99
                                          Hi
                                          I have a Citronic AC-1USB.
                                          When I run a turntable into it and then try to record it. The volume is too loud and distorting. In the red. Mainly 12” Singles. I haven’t tried a CD into it yet. I’m wondering if there is any way to bring the volume down inside the unit itself. Change a part or two. Put a small pot somewhere as there are no adjustments at all in there. I’m looking for the schematic but not found one yet.
                                          Heres the circuit board inside.
                                          Cheers
                                          04-30-2024, 06:17 AM
