LG RZ-37LZ55 stuck in Standby
  • Chungalin
    • Jul 2014
    • 422
    • Spain
    I’m stuck too with this one.
    Red Standby LED on. Doesn’t power on from keyboard nor remote. ST_5V (5V standby power) correct. ON/OFF signal to PSU is always 0V (so it’s normal that power supply doesn’t start other voltages). PWR_ONOFF signal from CPU is 3V, and this brings Q1001 to short ON/OFF with GND, so looks like it’s nothing from PSU (it looks good, nothing bloated, nothing blown and good ESR). Tried disconnecting all cables from PSU to MAIN, and shorting ST_5V with ON/OFF. Relay clicks, so it looks that PSU would power on if CPU could activate it.
    IR receiver signal present on MAIN connector from front PCB. Keyboard has 3V and reacts to Power keypress.
    So, to me, looks like a MAIN problem. Anything I can do?
  • fpsousa
    • Dec 2015
    • 29
    • Portugal
    Re: LG RZ-37LZ55 stuck in Standby
    Hi
    Yes, it seems to be the CPU chip that don“t produces the on/off signal.
    Has you measure the crystal clock frequency? and the voltages on main that suplies the CPU?
    Sometimes the eeprom must be exchanged and sometimes is a problem off firmware.
    • Chungalin
      • Jul 2014
      • 422
      • Spain
      Other small voltages (3.3V, 1.8V...) were correctly generated from the ST_5V.
      I’ve dismissed this one, no time to keep messing with it. Thanks for the help.
      • sordids999
        • May 2013
        • 2157
        • uk
        http://www.ebay.co.uk/itm/LG-RZ37LZ5...AAAOSwqu9VGdDu
        7 Piece REPAIR Kit for LG RZ37LZ55 Power Board 6709900002A 6870TD30D10 EAY33043001 Repair Kit.
        Fixes the following symptoms:
        -stuck in standby
        -won't come on
        -dead
        • lepak06
          TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
          by lepak06
          Hello
          I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
          The TV is faulty with stuck in Standby RED LED. Can't power the TV.
          Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
          All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
          But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
          01-12-2023, 01:43 AM
        • toty79
          Hisense LTDN50K220WSEU stuck in standby
          by toty79
          Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
          As per Hisense tv title LTDN50K220WSEU stuck in standby
          PSU rsag.820.5687 HLL 4855WF
          Main rsag 7.820.5842
          I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
          05-01-2022, 04:39 PM
        • lego1234567
          LG 32LB1R - stuck in standby mode
          by lego1234567
          Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
          What could be the problem ? Thanks...
          01-21-2024, 03:39 AM
        • Rusenga
          Samsung UA39EH5003R Stuck on standby
          by Rusenga
          Hi techs, I have a Samsung ua39eh5003r which switches on and then goes to standby. I have to wait for a day or two for the tv to switch on again, all the time it is stuck on standby. I have checked the voltages on the power supply board on both occasions when it is on and off and these are my findings:
          Connector CNM803:
          TV ON
          Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.96v; Pin6(BLU_ON/OFF)- 4.41v; Pin8,9,10- grnd; Pin11,12,13- 5.16v; Pin14(Power ON/OFF)- 3.3v
          TV OFF
          Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.06v; Pin6(BLU_ON/OFF)-...
          09-18-2021, 11:51 AM
        • Ukdigger
          Samsung UE46f5000AK Stuck on Standby
          by Ukdigger
          When the Main board is disconnected, the back lights are off but tapping on the chassis makes them light up and all voltages are then good. Connecting the main board up makes the TV work normally until moved. LED INERFACE STRIP BN41-01971A has a short on the first 2 pins on the left of the picture, the cable tests good. All the other pins and all LED strips test good. Is there an easy way to fix the short or do I need a new interface. Any help would welcome.
          PSU number bn44-00610A L46SF_dpn
          1 B13v 12.4
          3 B13v 12.4
          5 Vamp 12.4
          7 Vamp 12.4
          9 GND...
          08-08-2024, 09:17 AM
